what time did the engine blow
Old Jun 15, 2003 | 10:00 AM
reditr's Avatar
Default what time did the engine blow
I installed drag gen 3 turbo kit in my itr and went for a spin i thought that my tial was setted at low boost but it was setted at full boost as i bypassed the pipe of it. i gave the engine about 4 spins just in second gear and at the 4 one the engine made several misfires at around 6000rpm, the check engine light on that time. i switched the car off, on again and everything came normall again. the day after i have leant a boost gauge and noticed that the car was being boosted at around 17 psi on everything stock. then i haved noticed that by missing link was fault too because everytime the boost was entering, the check engine would lite again. After all this the engine was running good without smoke without anything, but there was only one problem the day after i have found about 3 circulular oil patches underneath the car , and was coming from the oil tank breather which is situated underneat the air intake manifold. Again the car was still running perfect until i went for another drive and in third gear at around 7500rpm i heard i misfire and loads of white smoke came out. i opened the engine and found no: 4 sleeve cracked and the 4 pistons broke from the ring land. What do you think ?the pistons broke the first time when i boosted 17psi and then afterwards the sleeve had cracked after does 2days boosting at just 6.5psi? or everything broke when i was just boosting at 6.5psi? Can any body help me in this find? out thanks in advance.
Old Jun 15, 2003 | 10:02 AM
Andrew 825SM's Avatar
Default Re: what time did the engine blow (reditr)
Ouch man sorry to hear that. But why do you want to know when they broke if you already know what you damaged.
Old Jun 15, 2003 | 10:24 AM
omahaturbocivic's Avatar
Default Re: what time did the engine blow (Andrew 825SM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">Ouch man sorry to hear that. But why do you want to know when they broke if you already know what you damaged.</TD></TR></TABLE>
He probably wants to be sure he knows what damaged it so it does not happen next time around. I would say the 17psi probably did more damge then you think and the 6.5 finished it off, unless it was tuned bad and you got really lucky at 17 psi. Try again, never run without a boost gauge , run conservative fuel and timing till its tuned and hopefully it should run pretty good then.
Old Jun 15, 2003 | 10:55 AM
Tinker219's Avatar
Default Re: what time did the engine blow (omahaturbocivic)
damn...whenever you see more than 6 psi on stock internals, let off the gas!
Old Jun 15, 2003 | 11:31 AM
Jared's Avatar
stock internals? your sig says sleeves and built engine?
Old Jun 15, 2003 | 12:00 PM
madman604's Avatar
Default Re: what time did the engine blow (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">damn...whenever you see more than 6 psi on stock internals, let off the gas! </TD></TR></TABLE>
6???? seems awfully low to me
Old Jun 15, 2003 | 01:53 PM
JAY's Avatar
JAY
Default Re: what time did the engine blow (Turbo E)
id say 10-12 is about the limit
Old Jun 15, 2003 | 02:00 PM
Mr. Softee's Avatar
Default Re: what time did the engine blow (JAY)
damn you cracked a darton sleeve? there was some serious detonation going on...
Old Jun 16, 2003 | 11:53 AM
JDM97R's Avatar
Default Re: what time did the engine blow (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">damn you cracked a darton sleeve? there was some serious detonation going on...</TD></TR></TABLE>He said the first time when he boost it 17psi was on stock internals.Now he is building it again with darton sleeves etc...I think that the damage of the sleeve was the first time when it was 17psi.What do you think?
Old Jun 16, 2003 | 12:20 PM
reditr's Avatar
Default Re: what time did the engine blow (Jared)
My sign says what i am building write now. At that time i had stock internals guy Thanks for all you help.
91accord22l
Jun 16, 2010 04:29 PM
pjr710
Jan 5, 2009 11:15 PM
CB5F22A1
Oct 9, 2005 01:46 PM
seanjohn81
Sep 12, 2002 10:57 AM
CWBETB
Oct 8, 2001 11:59 AM
