What psi will be safe to run ls auto?
Old 01-06-2002, 11:44 AM
New User
shpae's Avatar
Default What psi will be safe to run ls auto?
I have a rev-hard stage2 kit on my floor. I've plan to install kit in next 2 weeks.
All i have mod is greedy evo cat back and AEM power pulley. I am gonna use stock auto trany and stock tranny cooler with 6~8psi.
i just wonder what psi setting will be save my tranny and gain some desecnt hp?
Also, what kind of 1/4 times i can expect?
Old 01-06-2002, 12:27 PM
not so civic's Avatar
Location: gravity rides everything...everything will fall, se GA/ne FL
Default Re: What psi will be safe to run ls auto? (shpae)
if possible only run the 8 and no more when you race and only. try to keep 5 maybe 6 for dailying. i ran a constant 6-7 psi through my hybrid turbo when it 'was' auto. ran 8.61 1/8ths and low 13 sec quarters but that is a hybrid app where i have 600 lbs on you. you might run low 14...maybe high 13's. after beating the hell out of the auto for maybe 4 months it finally gave. so be careful and don't do neutral rev drops! just brake launch (you'll only get 2k rpms on launch with brakes which you'll still spin so don't worry too much about a high stall converter yet). if you plan to build up the tranny, it's not the torque converter that is going to hold your power like everyone thinks is what that does. the converter only allows you to brake launch at higher stall like 4-5k rpm is ideal. a heavy duty clutch plate/pack kit is what's going to allow you to not 'slip as much' and hold more boost and more power output. contact levelten.com. a clutch plate kit is only $300 but cost about $600 to get put in. that is just labor for if you took the tranny off and had a shop do it. it will definitely cost more if they have to work with getting the tranny out. if you are going to do anything to the auto...get the clutch packs that are heavy duty from level 10. they claim it'll 'bullet proof' your tranny. so hope that helps...not too many people help out the auto racers so be fortunate that i have been through the task and know what you shouldn't do. i pushed the stock auto to it's limits and don't boost more than 8...still i think that is too much for it because it'll hit the rev limiter from slipping too much at that psi. it's fun nonetheless to have a fast auto...i would rather have a fast turbo auto than a slow *** stock gsr or something...si...ls. they are no fun to drive even though they are standard. good luck with the install and be careful with the auto man.
Old 01-06-2002, 12:31 PM
that girl in your avatar has a very sexy body...nice panty shot btw even if it is your girl. she has a nice lower section.
Old 01-07-2002, 09:54 AM
therealciviczc's Avatar
Default Yeah really...
Who is the chic? Very nice. Full size pic?
Old 01-07-2002, 02:03 PM
New User
DamonBoost's Avatar
Default Re: Yeah really... (therealciviczc)
Until you give us a full size pic you get no more information..
Old 01-07-2002, 04:38 PM
Smarter than you
DIRep972's Avatar
Default Re: Yeah really... (Damon501)
post the rest of the picture and well tell u.
Old 01-07-2002, 06:24 PM
New User
shpae's Avatar
Hahaha, u guys are so funny!
that picture was downloaded from some korean XXX sites.
I think their add: http://www.ksex.net then go to photo if u can read those lang..
there are tons of pictures like that, u can look around!
Old 01-07-2002, 08:50 PM
What is this crap?
falcongsr's Avatar
Default Re: Yeah really... (shpae)
that page doesnt load. come on! dont be a hater.
Old 01-07-2002, 09:36 PM
New User
shpae's Avatar
Default Re: Yeah really... (falconGSR)
Mine works fine!
If not u need some korean language!
Sorry!
Old 01-08-2002, 05:42 AM
BluLuder's Avatar
Ive been pushing 5psi and dont see a problem.. Only twice have I turned it up to 7psi and I think thats pushing my old auto tranny a lil much. 'cool how it stays in boost huh'
Spoogen_1
10-11-2006 03:15 PM
clipseintegra
04-02-2003 11:01 AM
wonny
06-13-2002 09:06 PM
shpae
07-26-2001 07:29 AM
Quick Reply: What psi will be safe to run ls auto?
