tapping oil pan for drain line?
Old Feb 23, 2004 | 05:45 PM
dan89crxsi's Avatar
Default tapping oil pan for drain line?
I did a search already and only came up with 2 posts which didnt meet my needs....I was wondering if someone could post pics of their tapped oil pan so as I have a few references of how to do it I have one of these and am wondering a few ways to attach it to the oil pan
Old Feb 23, 2004 | 05:49 PM
eghatchproject's Avatar
Default Re: tapping oil pan for drain line? (dan89crxsi)
Just drill in between the holes where the bolts would go towards the right side of the pan. At least that is where I drilled on my D17 oil pan. Main thing to worry about is whether or not you can get the bolts back in with the fitting and return line installed.
Old Feb 23, 2004 | 05:59 PM
Bailhatch's Avatar
Default Re: tapping oil pan for drain line? (eghatchproject)
Drill a hole that the threaded part of the fitting threads into almost all the way so the wrench flats are close to the pan. Get the pan down to bare metal and weld a nice bead around it on the outside of the pan. You can do the inside but if the outer weld is done right it will be overkill anyway.
Old Feb 23, 2004 | 06:24 PM
5STAR3's Avatar
not mine but do this!
make sure you weld it, or else Rick James will come grind his feet into your sofa
Old Feb 23, 2004 | 06:56 PM
Cruiser G's Avatar
Default Re: tapping oil pan for drain line? (envision2teg)
clean
Old Feb 23, 2004 | 07:04 PM
vietjdmboi's Avatar
man thats one nice oil pan.. where can i purchase the blue anodized cap?
Old Feb 23, 2004 | 07:32 PM
5STAR3's Avatar
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">man thats one nice oil pan.. where can i purchase the blue anodized cap?</TD></TR></TABLE>
why? are you going to tap it and then plug it?
Old Feb 23, 2004 | 07:49 PM
vietjdmboi's Avatar
well, i want to tap my oil pan so that in the upcoming month when i install my turbo i dont have to worrie about getting it tapped because i would aleady have it done.
Old Feb 24, 2004 | 08:44 AM
opto_isolator's Avatar
Rick James - HA! I saw that Chapelle's show too....what a riot!
Old Feb 24, 2004 | 09:36 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: tapping oil pan for drain line? (opto_isolator)
IM RICH BITCH!!! That show is the ****...
Sean
Old Feb 24, 2004 | 09:45 AM
DubyaAye's Avatar
sorry to thread jack. where can i get one of those fittings to tap the oil pan?
Old Feb 24, 2004 | 10:43 AM
dan89crxsi's Avatar
Default Re: tapping oil pan for drain line? (DubyaAye)
stan at fast-turbo.com has a nice oil drain kit i just ordered my feed line kit from him cant wait until i get it
delslow45
Apr 3, 2011 07:14 PM
Dc295kid
Nov 18, 2008 12:54 AM
josh0407
Aug 24, 2007 04:30 PM
MBlake55
Mar 8, 2006 06:11 AM
420aNT
Mar 9, 2003 10:26 PM
