timing under boost
Old May 29, 2002 | 05:00 PM
no show all go's Avatar
Default timing under boost
who can tell me what kind of timing advance they are running under boost.
im running 30 deg timing advance @ 1.4bar.
havn't played with advance yet... so not sure where that sits?
Old May 29, 2002 | 05:20 PM
Mr. Vapor's Avatar
Default Re: timing under boost (no show all go)
im running 310's with the 8:1FMU, aux fuel pump and stock internals.
run 7lbs.
i was told to retard 2 degrees.....so this is what i've done. is this correct? been running 8months no problems with it. i should be advanced? this doesnt sound right.
Old May 29, 2002 | 05:23 PM
technine's Avatar
30 deg @ 1.4 bar... DAAAMN! Even if I advance to 20 or more I get pinging and that is NA! Damn 1.4 bar?!?! 20psi?! 30 deg advanced!
Old May 29, 2002 | 05:40 PM
ekb18c's Avatar
What?
Old May 29, 2002 | 05:51 PM
GruvyTune's Avatar
New User
Kaboom!
Old May 29, 2002 | 06:23 PM
SIK IN DA HED's Avatar
New User
uhmmmmm huh?
Old May 29, 2002 | 11:28 PM
inspyral's Avatar
Default Re: timing under boost (dlplayboy)
I'm running stock timing(12 degrees - D16Y8), 8lbs daily.
Old May 30, 2002 | 12:10 AM
turbopimp's Avatar
30 degrees advance???? WTF???? You sure you're reading the timing light correctly? Something's not right here...
Old May 30, 2002 | 12:41 PM
Default Re: timing under boost (turbopimp)
don't need to. the data logger gives me that info.
Old May 30, 2002 | 12:45 PM
Default Re: timing under boost (technine)
you know to make hp you need timing advance. the more boost/rpm the more advance that is required to burn the same amount mixture. retarding timing is mainly a fail safe. but with good tuning and fuel delivery retard is not needed.
Old May 30, 2002 | 01:12 PM
dustin's Avatar
Ahh, so many people here misunderstand the difference between static ignition advance at idle and advance at high RPM. As RPMs increase, there is LESS TIME between each combustion event, but the fuel still takes near the same amount of time to burn. Thus to achieve max cyl pressure at the right time, the ECU advances ignition timing so that spark occurs earlier.
The ECU controls ignition timing... turning the distributor just offsets the tdc sensor input to to the ECU so it is fooled into earlier or later spark...
30 deg advance is a lot for boost. Are you sure you are not just reading max ignition advance (i.e. very low load)...
HTH
Old May 30, 2002 | 03:11 PM
Default Re: timing under boost (dustin)
i use the tec3 standalone. the timing maps are fully adjustable. with the help of the software i created the table. during cruising and light throttle timing is between 18-24 degrees. @ 7000rpm & 1-1.4 bar timing in the table is 30.
confirmed by the data logger.
im trying to figure out if its too much. car seems fine no detonation recorded by the knock sensor.
but ya....people don't understand that there are 3 seperate timing factors. ignition,cam, and crank.
crank being very import. to make huge power.
Old May 30, 2002 | 05:11 PM
Sonny's Avatar
I ran as high as 29 deg advance @ 8 psi on my JRSC'd B16A. I was also running the stock exhaust which I think allowed for a little more aggressive timing.
Sonny
Old May 30, 2002 | 07:51 PM
LsTurbo91's Avatar
Default Re: timing under boost (Sonny)
any higher than 25degrees @ 6-10lbs/6000rpm on my b16 I pick up slight detonation on my J&S with 91 octane. 10.8-11.5:1 A/F ratio.
93civciv
Dec 4, 2007 05:23 PM
Sinner
Oct 1, 2003 04:21 PM
wzcb08
May 19, 2003 07:47 PM
TurboDC4
Feb 7, 2003 02:29 PM
808eg6
Jun 24, 2002 07:52 AM
