What kind of head gasket for boost???
Old Oct 12, 2001 | 11:56 AM
GSRacer's Avatar
New User
Default What kind of head gasket for boost???
what kind of head gasket should i drop in my GSR?? I want to lower the compression so i could boost my teggy up. What's the better head gasket out there??
Old Oct 12, 2001 | 12:23 PM
TurboInteg95's Avatar
Default Re: What kind of head gasket for boost??? (GSRacer)
just keep the stock one. With less compression you'll be able to boost more but you'll be making the same power as with lower boost and higher compression. Not only that but you'll lose low end power and increase turbo lag. The only benefit to low compression is it makes space for sloppy tuning.
Old Oct 12, 2001 | 12:37 PM
VaporTrail's Avatar
New User
OEM.
If the OEM gasket doesn't meet your needs, try a Cometic gasket. VERY high quality stuff, and because of it's OEM-like tri-metal composure, it has none of the hassles of a copper gasket. Affordable too!
Old Oct 12, 2001 | 01:23 PM
ArizonaTurbo's Avatar
I believe http://www.raceeng.com carries the Cometic headgaskets in either .030" or .040" . They are only $69.00 or so! Can't go wrong with one!
Old Oct 15, 2001 | 07:41 AM
GSRacer's Avatar
New User
Default Re: What kind of head gasket for boost??? (APEXSER)
good point turbols
Old Oct 15, 2001 | 08:09 AM
DR. ON POINT's Avatar
Banned
inline headgasket
chriscool888
Dec 18, 2011 03:17 AM
Blue94Accord
Oct 23, 2010 04:00 PM
golf-mk3
Feb 22, 2010 07:00 AM
BAZ
May 5, 2003 06:49 PM
Charles B.
Oct 29, 2001 09:26 AM
