Inline Pro head gasket
Old Oct 28, 2001 | 01:48 AM
Charles B.'s Avatar
Default Inline Pro head gasket
Has anyone ever used one of these? I saw an ad in Turbo mag that said u can boost up to 22 PSI with it and stock engine and ECU? Is this true? Who has it? How much did u pay?
Old Oct 28, 2001 | 01:54 AM
MiraiZ's Avatar
Default Re: Inline Pro head gasket (SuperDuperEG)
any pics? I doubt it...but a good head gasket does make life lovely
Old Oct 28, 2001 | 05:17 AM
B17aTrbo's Avatar
New User
i have one...i think i paid like 350 for it...dunno how much boost i can hold with it in place...later.
Corey
Old Oct 28, 2001 | 05:31 AM
DragII's Avatar
25 Year Member
Default Re: Inline Pro head gasket (B17aTURBO)
Jinxproof99 on this board runs 20+ psi on stock internals using this gasket.
Old Oct 28, 2001 | 05:32 AM
Kamin's Avatar
Default Re: Inline Pro head gasket (DragIIcivic)
ehh thats one of those things that sounds too goo to be true
a head gasket allowing 20lb of boost?
hmm...
Old Oct 28, 2001 | 07:02 AM
Bumnah's Avatar
Default Re: Inline Pro head gasket (KAMiN)
It's just a head gasket which is thicker bring compression down. That's all it is. The idea probably works, but since you are plannin' to boost your car why not do it right, and build it up and have it be reliable also. It'll probably run better too.
Just my $0.02
Old Oct 28, 2001 | 07:21 AM
Blown90hatcH's Avatar
Default Re: Inline Pro head gasket (Bumnah)
It is a thicker headgaster that drops the compression down 1 point. Turbo EG6 had one on his stock gsr hybrid hatch....15psi too long and melted some pistons.
Old Oct 28, 2001 | 07:55 AM
Jared's Avatar
It's great for the cash. I had one on my turbo B16 and ran 12psi daily driven for quite a while without problems It's all about tuning.
Old Oct 28, 2001 | 08:03 AM
earl's Avatar
Default Re: Inline Pro head gasket (Blown90hatcH)
I use a Cometic head gasket and boost over 20 lbs. They are about $100 but are hard to find. Anyone have a good source for these gaskets? BTW they are re-usuable. I had to pull my head and reused the same gasket and it is still working perfectly. I've e-mailed Cometic twice but have not received an answer.
Earl
Old Oct 28, 2001 | 08:44 AM
XforgivenX's Avatar
New User
I have one and I run .8 bar, daily driven, no problems at all. I've been told I can run up to 20 pounds of boost on race fuel (116 octane) but I haven't tried it yet.
Old Oct 29, 2001 | 06:45 AM
Dublocivic's Avatar
Default Re: Inline Pro head gasket (earl)
Earl,
Did you ask Larry about one? I know he says that he has HG's for a few different bore diameters.
Old Oct 29, 2001 | 08:26 AM
00 Si's Avatar
New User
I am thinking about getting one. I want to run only 10psi out of my Greddy kit so I figured I really don't need to buy rods and pistons if I can do a headgasket for a lot less. Just my opinion though.
Old Oct 29, 2001 | 09:26 AM
threatcon13's Avatar
New User
Default Re: Inline Pro head gasket (00 Si)
any kind of plans involving boosting 20lbs on stock internals regardless of headgasket choice require meticulous tuning..be sure you know what youre doin and have everything set up right before tryin to boost 20 lbs w/ a headgasket and stock internals.
chriscool888
Dec 18, 2011 03:17 AM
Kris's turbo
Jun 6, 2008 07:40 PM
civicminded3111
Oct 29, 2007 10:14 AM
GSRacer
Oct 15, 2001 08:09 AM
The Punisher
Aug 16, 2001 10:00 PM
