inline pro gasket to lower compression. good idea?
Old Feb 21, 2010 | 05:44 AM
golf-mk3's Avatar
Default inline pro gasket to lower compression. good idea?
what do you guys think of a 3mm head gasket to lower compression on a ls-v. i was hoping for high 300s but no funds for a built block. so i was wondering if that gasket could be a way out?
Old Feb 21, 2010 | 04:40 PM
golf-mk3's Avatar
Default Re: inline pro gasket to lower compression. good idea?
ANYONE?
Old Feb 21, 2010 | 04:46 PM
_kiid's Avatar
alot of ppl do thicker head gaskets to low compression
i have a cometic
Old Feb 21, 2010 | 05:01 PM
EKlscoupe_98's Avatar
should be able to do mid 300 without using inline pro head gasket..imo... link to 400whp stock ls/v for an example
http://forums.evans-tuning.com/viewt...hp?f=38&t=5619
Old Feb 22, 2010 | 06:20 AM
Kyle R's Avatar
Old Feb 22, 2010 | 06:24 AM
boostedEF91's Avatar
no need for that gasket.. just leave the higher compression and run less boost. with lowering the compression you will have to increase the boost to get more horsepower rather then just leave the higher comp and run less boost.. either way tho you will be fine. But save yourself time. just leave it how it is.
Old Feb 22, 2010 | 06:48 AM
99JDMHATCH's Avatar
I actually have one installed in my car. I don't think its bad def worth the money. Been running 343whp for about a year and half now. As most will say OEM is best though.
Old Feb 22, 2010 | 07:00 AM
Schister66's Avatar
Man U FTW
It probably isnt necessary; however, your fuel choice will play a slight role in this decision. If you're going to be pushing it to the edge on a given octane, you may consider lowering your static compression for the added wiggle room. Having said that, i'm sure the stock compression is probably fine...
madman604
Jun 2, 2003 11:09 AM
fastludeh22
Oct 14, 2002 01:52 PM
TerdFerguson
Oct 6, 2002 05:59 PM
GSRacer
Oct 15, 2001 08:09 AM
joe pagolac
Aug 21, 2001 09:02 AM
