Head Gasket
Old Oct 22, 2010 | 01:06 AM
Blue94Accord's Avatar
Default Head Gasket
So I was just wondering about the different thicknesses of headgaskets. I dont know to much about them and was wondering if anyone can explain why you would want to have a thicker gasket.
I was using a cometic .60 and i think i blew it on my h22 low comp turbo. thinking maybe it might have been too thick or maybe i should buy a better name gasket.
Anyone know any good headgaskets for 87.5mm h22a darton sleeved?
Old Oct 22, 2010 | 02:12 AM
SD_Lurker's Avatar
HT White Ops
Default Re: Head Gasket
Having a thicker head gasket will yield a lower compression ratio.. Having a thinner head gasket will yield a higher compression ratio.. Other than sealing the block and head the different thickness is used to change the compression ratio to ones likes.
Old Oct 22, 2010 | 02:14 AM
Redline130's Avatar
A thicker headgasket would lower your compression.
OEM headgasket....never had an issue with one.
Old Oct 22, 2010 | 07:36 AM
so oem would be good for like 25psi of boost?
Old Oct 22, 2010 | 08:03 AM
komat's Avatar
yes
people use oem with 30+
Old Oct 22, 2010 | 10:53 AM
mechanix619's Avatar
Use a Golden Eagle head gasket. Golden Eagle uses OEM hg and machines them to fit any application.
http://www.goldeneaglemfg.com/index....igngi6sj81jvb6
Old Oct 22, 2010 | 10:54 AM
The boost level has nothing to do with your head gasket.
Also, talk in terms of horse power, stating a boost level doesn't mean much. First determine a horse power goal and buy parts to meet that goal; the boost level required to make that horse power goal will be determined by what parts you use. For example, if you use a small exhaust like 2.25 inch you might need 14psi to make your horse power goal but if you use a 3 inch exhaust you might only need 10psi of boost to make the same power.
Old Oct 22, 2010 | 04:58 PM
My first gasket was off of golden eagle and then i went cometic my second time. Well I know that your setup varies your boost level and horsepower. I know that with my current manifold i wont make my 500hp goal so I am just going to get it tuned to around 20psi and what ever that makes it makes. Till i get my manifold and tial wastegate.
I made 284hp and 248tq on 11psi
low compression and a log manifold didnt help with the hp/boost level
anyone know any site to get arp headstuds for less then 120?
Old Oct 22, 2010 | 05:09 PM
ashb82's Avatar
http://cgi.ebay.com/ebaymotors/ARP-H...Q5fAccessories
Old Oct 22, 2010 | 05:12 PM
for less then 120 lol. i use to know a site for like 110$ but i cant find it anymore
Old Oct 23, 2010 | 10:08 AM
I wouldn't trust eBay for something as important as headstuds. Just pay the full price for peace of mind.
Old Oct 23, 2010 | 03:48 PM
arp headstuds is arp headstuds
unless you get knock offs
Old Oct 23, 2010 | 04:00 PM
Hmm, that's why I said to stay away from eBay. Is the $10 worth the risk for getting fake parts?
.::Lee::.
Feb 17, 2004 08:50 PM
BAZ
May 5, 2003 06:49 PM
Evs-One
Mar 3, 2003 01:09 AM
Audi RS4
Mar 20, 2002 04:58 PM
