What did you use to file down block?
Old May 20, 2002 | 03:29 PM
T4sol's Avatar
Default What did you use to file down block?
Like the questions says what did u use to file the block down?? Can this be done with a file from home depot or maybe some sort of attachment to a drill???
Old May 20, 2002 | 05:40 PM
Captain Save-a-Hoe's Avatar
Default Re: What did you use to file down block? (TurboKid)
Dremel tool
Old May 20, 2002 | 06:13 PM
92JDMSiR's Avatar
if you do it by hand it's goin to take forever. if youcan get your hands on an air grinder thats the best bet. dremel work work though. i used an air grinder
Old May 20, 2002 | 07:06 PM
CovertFI's Avatar
Default Re: What did you use to file down block? (92JDMSiR)
hack saw and die grinder with cuting tool
Old May 20, 2002 | 07:23 PM
Darin D.'s Avatar
Default Re: What did you use to file down block? (94hondahybrid)
a sawzal! took 2 seconds..
Old May 20, 2002 | 09:43 PM
paulzy's Avatar
Default Re: What did you use to file down block? (Willis)
I love sawzils
Old May 20, 2002 | 11:30 PM
Flamenco-T's Avatar
Default Re: What did you use to file down block? (Sayang)
use an electric drill and use a 3/8" drill bit, use titanium...
drill a few holes about 3/4" from the edge of the block...
once you have a rugged edge, use a smaller bit like a 1/4" and smooth the rugged edges left behind by the larger one and file it down until it is very smooth....
you want to dull out the sharp edges, you don;t want it to puncture the turbo..
ALSO, once you're done, install the manifold and turbo on, and check the clearance from the bottom of the car...
as long as you have 1/3" of clearance from the block to the turbo, you're fine
the whole process should take you about 15-25 minutes and good luck with your sore arms..hehehehehe
stan
Old May 21, 2002 | 12:34 AM
VaporTrail's Avatar
New User
air grinder, leaves no messy residue
Old May 21, 2002 | 12:52 AM
LsTurbo91's Avatar
Default Re: What did you use to file down block? (VaporTrail)
electric grinder ... no need to recharge
Old May 21, 2002 | 08:07 AM
NeXtLeVeL_TyPe_R's Avatar
Default Re: What did you use to file down block? (LsTurbo91)
Electric grinder doesnt blow off like air does after recharge
PissedoffHONDA
May 23, 2008 08:21 AM
PrettyFastRide
18
Aug 26, 2006 10:50 PM
PSU-TEG
May 18, 2003 03:24 PM
SOUNDEFFECTS
Nov 26, 2002 07:23 AM
B18C-RnVA
Aug 25, 2002 08:29 PM
