wastegate problem
Old Apr 19, 2006 | 12:54 PM
wildman117's Avatar
Default wastegate problem
I just completed my b16 turbo system on my civic. The whole thing works great except that the car hits like 12- 15 psi boost on the stock motor. I ordered a 6psi wastegate, but it is a knock off tial. I have a single line running into it. Why does it boost so high. I also do not have the boost controller hooked up.
Old Apr 19, 2006 | 01:39 PM
dpetro1's Avatar
Default Re: wastegate problem (wildman117)
i would say there is either something wrong with the vacuum lines or the wastegate itself. go over all the line and make sure they are good. you def dont wanna be overboosting that much, unless you are tuned for it.
Old Apr 19, 2006 | 02:07 PM
non-VTEC's Avatar
also you might want to take the wastegate apart and make sure it really has a 6psi spring installed.........it could have the wrong spring installed by mistake.
Old Apr 19, 2006 | 04:00 PM
Boosted Chemist's Avatar
Default Re: wastegate problem (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">also you might want to take the wastegate apart and make sure it really has a 6psi spring installed.........it could have the wrong spring installed by mistake.</TD></TR></TABLE>
or its a pos ss auto, some work great some dont work at all.
D-meet07
Sep 23, 2019 03:06 AM
H22TurboNos
May 13, 2007 01:06 PM
TurbodTegSfaria
Oct 14, 2006 07:28 AM
LilCivic04
Jul 12, 2005 10:25 PM
_Cyclone_
May 4, 2005 02:32 PM
