wastegate
Old Jun 6, 2003 | 05:09 AM
SMOOTH97LUDE's Avatar
Default wastegate
I have a tial wastegate. it is routed so that the dump goes back into the downtube near mani really close to where the downtube bolts to the turbine. i have heard that for higher boost this setup will not work. is that true?
Old Jun 6, 2003 | 05:22 AM
b16ahybrid's Avatar
Default Re: wastegate (SMOOTH97LUDE)
Yeah if i recall, it's best to have 12''-18'' from the turbo downstream. Fed into the downpipe at a smooth flowing angle
Old Jun 6, 2003 | 05:31 AM
symba's Avatar
Default Re: wastegate (b16ahybrid)
exactly, you need to lengthen your tube to as close to the cat as possible(if you have one) and make sure it is at a good angle. Nothing perpendicular, you need to keep the gases flowing smoothly. You are creating too much back pressure right now for high boost application and are probably robbing yourself of a good 15-20 whp right now
Old Jun 7, 2003 | 07:52 AM
Default Re: wastegate (symba)
I saw the pics that k&s had of the max-rev mani, also mine is a max-rev mani.
Modified by SMOOTH97LUDE at 5:43 PM 6/7/2003
Aero91
May 11, 2009 01:43 AM
boostedhatch85
Oct 27, 2005 07:27 AM
16vt
May 29, 2005 10:55 AM
VTEC-DA
Sep 13, 2002 02:01 PM
BlackGSR
Apr 16, 2002 07:44 AM
