Have questions on changing turbos
Old Oct 26, 2005 | 07:47 PM
boostedhatch85's Avatar
Default Have questions on changing turbos
I wanna know what i need to do to change my setup i have from internal waste gate to a external waste gate.
Old Oct 27, 2005 | 07:11 AM
Boosted Power's Avatar
You'll need a manifold that will accept the external wastegate.
You'll need external wastegate itself. Tial or turbonetics works fine.
You'll also need a wastegate dump tube..either routed back into the downpipe or dumped somewhere where heat wont ruin anything.
That's pretty much it...other then that...you'll have to block off your internal wastegate hole with the correct flange with correct bolts for your turbo.
Get rid of your internal wastegate if you're serious about turbocharging.
Old Oct 27, 2005 | 07:27 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Boosted Power)
i have to disagree with the loss of the internal gate if you are serious about boosting, i had an internal gate on my t-type spooling 30-33 psi, no issues. if you arent having creep/spike issues and are happy with the boost you are running, you dont need an external gate. BUT if you are looking to upgrade, then the above is true. just my o.o2.
the only reason i say that, is i have seen too many ghetto hack jobs adapting an external gate to an internally gated manifold. they are atrocious. but again if you are going to go with a bigger turbo, different combination, then it may necessitate an external gate.
alex37211
Apr 8, 2009 03:50 PM
homicydalboy
Jun 4, 2007 06:12 PM
H2on0da3
Jan 4, 2006 09:43 AM
speedy108
Apr 26, 2005 06:31 PM
Alstare
Dec 18, 2002 01:20 PM
