Wastegate placement
Old May 29, 2005 | 10:28 AM
16vt's Avatar
Default Wastegate placement
I have an equal length turbo header that's divided,I'm about to intergrate the WG (Tial 44mm) and it'd be easist to go off of one side (ie 1-4 or 2-3) but I'm concerned about being able to control boost at higher levels,I was wondering anyones *expirience* good or bad only venting 2 cylinders instead of all 4.
Old May 29, 2005 | 10:37 AM
nfn15037's Avatar
Default Re: Wastegate placement (16vt)
YEs it is indeed *bad* to have the wastegate on only 2 cylinders. If you are running low boost or a small turbo that requires the wastegate to route a lot of exhaust gas around the turbine you will get creep with a crappy wastegate placement.
Old May 29, 2005 | 10:55 AM
DragSource's Avatar
nfn is right.
On a high flowing "equal length" manifold, even with the wastegate @ a 4 way collector people are still having creep issues if the wastegate is not given primary flow.
alex37211
Apr 8, 2009 03:50 PM
speedy108
Apr 26, 2005 06:31 PM
nolovenodie
Nov 8, 2002 02:43 PM
PolySquared
May 12, 2002 09:57 PM
