vafc hack above 10psi.
Old May 16, 2003 | 06:25 AM
platinum00's Avatar
Default vafc hack above 10psi.
can you run this setup at higher boost levels. like a even 1 bar.
if so is anything else needed.
platinum.
Old May 16, 2003 | 06:34 AM
T-Blaze's Avatar
U can but it's not advised... U will need a 2/3 bar map sensor and bigger injectors so u can trim the fuel back more...
But if u wanna run more than 11 psi get a Hondata.!!
Also do a search - there's sh*t loads of info on this.
Old May 16, 2003 | 06:36 AM
platinum00's Avatar
Default Re: (T-Blaze)
i did a search for afc hack. nothing much on above 11.
o i did not try archives.
thanks...
Old May 16, 2003 | 06:39 AM
platinum00's Avatar
Default Re: (platinum00)
another question.
why does everyone use hondata.
why not like sds or some other stand alone...
Old May 16, 2003 | 08:19 AM
shadowdawn's Avatar
Please dont try to push above 10psi on the vafc hack... you will most likely end up blowing your motor or have other problems.
Go standalone...
Most people use hondata on this board because theres so much support and tuners on here for it... thats pretty much it.
Old May 16, 2003 | 01:53 PM
platinum00's Avatar
Default Re: (shadowdawn)
thanks for the info..
platinum.
Bigplans06
Nov 28, 2004 08:14 AM
_Endless_
Jun 20, 2003 10:07 PM
seanjohn81
Feb 26, 2003 02:19 PM
Andrew 825SM
Oct 21, 2002 08:36 AM
CalvitoSol
Jul 22, 2002 02:33 AM
