vafc with check valves throws code at 12psi? map sensor
Old Dec 17, 2004 | 11:38 AM
  #26
Tad's Avatar
Tad
Default Re: vafc with check valves throws code at 12psi? map sensor (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Actually it means it will throw NO codes at any pressure above the max reading of the sensor provided the output to the ecu is scaled to atmospheric for the max reading of the sensor. Obviously he's coding because the ECU is still seeing boost at some point.</TD></TR></TABLE>
eehhh.. well that was confusing,
but yeah, the stock obdI map cannot run seeing over like 10-11psi,
i dont know about any atmospheric scaling of the ecu or whatever,
but anyone who tries to run over 10lbs on the stock map sensor is going to have their car run like sheeit.
and yeah I'd think this should be common knowledge.
but I definetely think it's this guys problem.
SDT Project EF
Aug 12, 2003 05:43 PM
wanttorace
Jun 11, 2003 06:55 AM
zCivic
Nov 6, 2002 07:00 PM
mracura
May 26, 2002 11:10 PM
Coldsi
May 14, 2002 04:49 PM
