V-AFC with Boost q'
Old Nov 6, 2002 | 08:50 AM
zCivic's Avatar
Default V-AFC with Boost q'
Considering prior to building up may B18A if I want to go Boost or not to Boost. I know with the ECU I would have to use check valves to trick the map sensor. Seeing I already have the V-AFC and that runs inline with the map sensor to the ECU will that trick it so it doesn't see boost or still need check valves? Just more useless knowledge I can use in the future really.
Old Nov 6, 2002 | 09:08 AM
GraphiteAccord's Avatar
Default Re: V-AFC with Boost q' (zCivic)
do a achrived search on the v-afc hack.
Old Nov 6, 2002 | 10:23 AM
zCivic's Avatar
So if I understand this the ECU still cann't see positive pressure from the MAP sensor if it does will CEL and Code it. What is this about the 3 bar map sensor. My friend has a Haltech and uses a 3 bar but would this work with honda's. I know you can change the setting for the sensor in/out that wouldn't affect anything either. Still would have to stay below 11PSI or check valves.
Old Nov 6, 2002 | 04:49 PM
CrX1988Zc's Avatar
no check valves or missing link etc. needed with vafc hack. i run 10 psi and no map sensor CEL at all.
Old Nov 6, 2002 | 07:00 PM
speedworks's Avatar
Default Re: V-AFC with Boost q' (CrX1988Zc)
if you do not use the hack you will need a missing link or a check valve.
SDT Project EF
Aug 12, 2003 05:43 PM
zCivic
Nov 6, 2002 11:12 AM
98civicEX
Sep 19, 2002 07:37 PM
98civicEX
Jul 2, 2002 07:16 PM
Greyout
Jan 25, 2002 09:08 AM
