turbo project not boosting, was boosting when first installed.need help
Old Feb 21, 2004 | 08:31 AM
lvf03's Avatar
Default turbo project not boosting, was boosting when first installed.need help
well this is my problem installed t3t4 on b20vtec last week first few days was boosting fine not really pushing it,street tuning with hondata.yesterday i took it out for somemore tunning first try boosting fine second try no boost.all lines are connected no leaks at all.also noticed that the turbine wheel on the intake side is not spinning at idle will spin when reved up but will only spin for a few seconds and then stop when off the gas.what do you guys think it is.i.am thinking maybe shoot bearings in the turbo.thanks
Old Feb 21, 2004 | 10:17 AM
lvf03's Avatar
Default Re: turbo project not boosting, was boosting when first installed.need help (lvf03)
anybody?
Old Feb 21, 2004 | 10:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
Shaft doesn't have to spin at idle [unless you're running a BB turbo], but it shouldn't start and stop abruptly like the way I think you're describing it. Make sure you're getting oil feed, make sure your oil return line isn't kinked/backed up, make sure your blow off valve or wastegate isn't stuck open. Your bearings in the turbo may have also crapped out.
Old Feb 21, 2004 | 10:45 AM
lvf03's Avatar
oil feed is ok blow off valve is ok. took the turbo off and found oil in my i/c piping does this mean turbo has shot bearings.
Old Feb 21, 2004 | 11:04 AM
eghatchproject's Avatar
Default Re: (lvf03)
oil is getting past the seals use 10w 30
Old Feb 21, 2004 | 11:15 AM
lvf03's Avatar
would not using 10w30 cause to have no boost?????
Old Feb 21, 2004 | 08:50 PM
DaX's Avatar
DaX
Loved
Community Favorite
Oil in your IC piping means oil is blowing by your seals. You probably need to rebuild your center section. Did you buy the turbo used?
Old Feb 22, 2004 | 05:53 AM
lvf03's Avatar
no bought it new would that cause it not to boost.
Old Feb 22, 2004 | 06:26 AM
pollito's Avatar
Default Re: (lvf03)
If your bearings are shot, then it cannot spin. So yes, it's probably toast
Old Feb 22, 2004 | 06:35 AM
SpoolnG2's Avatar
Default Re: (pollito)
you bought it brand new and its allready shot??? I'd say call up whoever u bought the turbo from and have a few words with them.
Old Feb 22, 2004 | 06:55 AM
GDM Z28's Avatar
Default Re: (SpoolnG2)
did you brake the turbo in?!? you said you put it on last week and the first night it was boosting fine. when you have a brand new turbo its always good to brake it in! so this sounds like user error.
lvf03's Avatar
i can spin the turbo by hand with a bit of resistance but can not spin it when playing with the impeller shaft left or right
Old Feb 22, 2004 | 07:01 AM
b16ahybrid's Avatar
Default Re: (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">did you brake the turbo in?!? you said you put it on last week and the first night it was boosting fine. when you have a brand new turbo its always good to brake it in! so this sounds like user error.</TD></TR></TABLE>
The way he described the first few days of using the turbo (light boost) was more then enough to break in the bearings.
Old Feb 22, 2004 | 07:04 AM
lvf03's Avatar
first few days was boosting only 5psi then tried 9 psi thats when it stoped boosting
Old Feb 22, 2004 | 01:46 PM
BoOsTiN Dc2's Avatar
u dont need to break in the turbo...
Old Feb 22, 2004 | 04:06 PM
b16ahybrid's Avatar
Default Re: (tRaCeBuStAbUsTeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">u don't need to break in the turbo...</TD></TR></TABLE>
Not breaking the turbo in per say, but more less letting the bearing get a good wear pattern before putting more stress on them. Kinda like an engine, it's good to let everything create a wear pattern before you make a bunch of red line runs...
I've heard your supposed to drive 500 miles before boosting ....IMO letting it idle (gets oil flowing good) for a few then driving around for the first 20 miles or so introducing boost a little at a time, each time boosting a little more..but thats just my opinion.
Old Feb 22, 2004 | 08:11 PM
Default Re: (b16ahybrid)
i just let it sit for a while then when i finally got to drive it i was boosting non stop for a miles and miles
CRX-Kid11
Jan 21, 2012 06:44 PM
L_J_Scheepers
May 2, 2008 06:12 PM
boostedcoupe1
Feb 16, 2008 06:46 AM
blackcrx16
Jul 16, 2007 05:44 PM
jdmcivic1999
Feb 12, 2005 04:05 PM
