turbo problem
Old Jan 26, 2008 | 02:22 PM
new2000civicex's Avatar
Default turbo problem
i have a boost gauge that has vaccuum gauge too. When the car is idling it is 20 h/g vaccuum, it slowly creeps up to 0 at about 3600 and gets to 5 psi of boost at about 4700-4800 rpms. is this normal to have so much vaccuum
my car is a 2000 civic ex with a d16z6 in it. its got a garrett t3/t04 57 trim .63 a/r, log manifold, tial 7psi 38mm wastegate etc.
i got it tuned and the dyno said i have 155whp and 127 torque.
that is very disappointing considering i have spent over $5000 on this thing, im only getting just over 5psi of boost even tho i have a 7psi wastegate, what can i do to make this thing make some more power?, i was looking fo about 200whp
minimum
also if i change the spring to a 10 psi, will i need another tune?
Old Jan 26, 2008 | 02:28 PM
Schister66's Avatar
Man U FTW
I'm not sure what would be causing that problem necessarily, but i'm not completely understanding you either. When you're idling, the 20 in/hg is fine, but the "slowly creeping to 0 ...." portion is where you lost me. Is that under hard throttle or just average driving.
With your setup and boost level, you should be making a lot more power than you are....there has to be some kind of problem. Do you have a dyno graph??
Old Jan 26, 2008 | 03:00 PM
Default Re: turbo problem (new2000civicex)
yeah i have a dyno but dont know how to post it here, the gauge is starting at 20 h/g and working its way up to 0 then goes to boost, i was thinking it should start at 0. sorry about not knowing a whole lot about this.
Old Jan 26, 2008 | 03:01 PM
should i get a new spring for my wastegate?
Old Jan 26, 2008 | 04:28 PM
Schister66's Avatar
Man U FTW
the gauge will start at 20 in/hg because at idle, the engine is in vacuum. During wide-open throttle, the manifold will read 0 because there is no pressure difference from outside the manifold to inside. The only engines that dont read vac at idle are diesels.
http://www.photobucket.com for pictures
Old Jan 26, 2008 | 05:02 PM
Default Re: (Schister66)
Old Jan 26, 2008 | 05:05 PM
ke98248's Avatar
I have almost the exact same setup as you (d16y8) -- I'm making around 220WHP on ten psi. Make sure your external wastegate has that metallic ring in it.. It fits inside the wastegate to the dumptube -- that will affect performance a lot.
As for the boost only hitting 5psi, check for boost leaks, at vacuum sources, couplers on the intercooler piping, etc..
Old Jan 26, 2008 | 05:06 PM
Schister66's Avatar
Man U FTW
Do you have the graph of the boost log vs power created?? Its a fairly typical graph to have...
Old Jan 26, 2008 | 05:07 PM
no this is the only one they gave me
Old Jan 26, 2008 | 05:30 PM
Default Re: (new2000civicex)
i'll check all the vac lines and couplers in the morning, ke98248 do you have a stock block and head? or is it built?
Old Jan 26, 2008 | 06:06 PM
Schister66's Avatar
Man U FTW
I'm going to assume his engine is stock...D series engines are safe stock in the 220-240whp range although many have gone further.
Old Jan 26, 2008 | 06:12 PM
wow!, so i'm way off from what i should be then
when i first got the car it seemed like it was alot faster, than about a week after i noticed it didn't have the same pickup as it did, it may that something came loose
I will check tomorrow
thanks for your help
Jason
Old Jan 27, 2008 | 04:01 PM
ke98248's Avatar
All stock internals, yes.
Old Jan 27, 2008 | 04:46 PM
Default Re: (ke98248)
I checked this morning, evrything looks like its hooked up correctly. no leaks anywhere as far as i can tell.
Anything else i should check?
Old Jan 28, 2008 | 01:18 PM
OMG B16's Avatar
Who is tuning your car?
V-SPEC 1
Feb 19, 2013 07:43 PM
millertime1085
Sep 27, 2008 08:11 PM
iTz On!!!
Mar 18, 2008 06:10 PM
rickturboteg
Aug 7, 2006 04:36 PM
swlabhot
Apr 16, 2003 04:14 AM
