turbo noob please help
Old Aug 11, 2009 | 05:06 PM
uberEFtuner's Avatar
Default turbo noob please help
Plain and simple I want to do something different!
So I want to do a rear mount turbo. The question is, why do i need to plumb oil from the motor?
Why can't I make a oil reservoir and pump oil in a circle in the back of the car? Does the turbo need hot oil?
Old Aug 11, 2009 | 05:42 PM
OLD_HATCH's Avatar
Default Re: turbo noob please help
Why not go with a traditional setup with the turbo in the engine bay? There are many many parts available for the f series and would make everything simple, not to mention that turbo might too small for a rear mount.
Old Aug 11, 2009 | 07:05 PM
I want to do what i said. That's why I said it dammit! Mostly I want to know about the oil line.
Old Aug 11, 2009 | 09:13 PM
jhammond_82's Avatar
Reject Papi
you're gonna need some sort of pump to circulate the oil. and if you keep acting like that, noones gonna wanna help you jack ***.
Old Aug 12, 2009 | 12:17 AM
xander1100's Avatar
considering that a turbo is spinning like 10x faster than your RPMs it builds a lot of heat, the oil helps keep it from overheating. dont oil pumps run off of the engines power?
Old Aug 12, 2009 | 07:33 AM
90civichbsi's Avatar
The guy was simply trying to offer some good advice. Your gonna end up spending way more money for worse results than a traditional setup. While it it possible to do a setup like you are wanting I'm sure the people that know how to aren't going to help you with an attitude like that.
Old Aug 12, 2009 | 08:13 AM
Ls_dx's Avatar
the turbo doesnt need oil.. anyone who tells you otherwise, is a liar, and a fatmouth!!
do twin rear mount t70's off of ebay and post pics.
Old Aug 12, 2009 | 07:24 PM
I found my answer here is a site http://www.rbracing-rsr.com/oilsystems.htm under the chart at the bottom they say that they do just what I want. They use a separate oil system for the turbo!
Old Aug 14, 2009 | 03:48 AM
dantamparacer's Avatar
so delete your post so other people dont waste their time trying to help you out!
Old Aug 14, 2009 | 06:19 AM
Bseriescivic5's Avatar
stop wasting our time if your just going to find a link like that and convince yourself of what you had already set in your mind. There was absolutely no need to make a post for this.
Old Aug 14, 2009 | 07:30 PM
Um I found some pretty cool information about turbo oiling systems!! In my opinion
Are you mad that I found good information?
boostedb20z
Nov 14, 2009 10:12 PM
AccordVT
Jul 30, 2008 07:51 PM
Project99EK
Dec 29, 2004 03:32 PM
B18c1CivicTurboed
Jun 3, 2003 08:33 AM
89civic1.8T
Jun 19, 2002 01:42 PM
