TURBO CLOCKING PROBLEM!!!!!! HELP PLEASE!!
Old Aug 8, 2004 | 08:07 PM
a2sportcompacts's Avatar
Default TURBO CLOCKING PROBLEM!!!!!! HELP PLEASE!!
ok i got a garrett t3 turbo out of a saab900, i clocked the compressor side but the exhaust side is givving me hell, it looks like the bitch is rusted shut, i just put some PB blaster on it, hit it with a sledge, nd still no budge, is it time to use a propane torch? would that even work?!
Old Aug 8, 2004 | 08:30 PM
Default Re: TURBO CLOCKING PROBLEM!!!!!! HELP PLEASE!! (Steeze)
help. please!
Old Aug 8, 2004 | 08:35 PM
gritsak's Avatar
have you tried spraying it with some pb blaster and letting it soak in for awhile? that **** works wonders
Old Aug 8, 2004 | 09:53 PM
Default Re: TURBO CLOCKING PROBLEM!!!!!! HELP PLEASE!! (gritsak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steeze &raquo;</TD></TR><TR><TD CLASS="quote">i just put some PB blaster on it</TD></TR></TABLE>
yup any other ideas?????
Old Aug 9, 2004 | 02:43 PM
ok soaked it with PB blaster, torched it for 1/2 hour, BEAT it with a sledge, this bitch wont move! does it have turbo guide pins? also i think i may have screwed it up a lil bit the exhaust fins are rubbing a lil bit on the housing, but if i push it up a lil bit it stops, will this also affect performance?
Old Aug 9, 2004 | 04:09 PM
SOHC_MShue's Avatar
Default Re: (Steeze)
that may not be good
Old Aug 9, 2004 | 04:25 PM
Sketch_hs's Avatar
get a new or rebuilt turbo.
Old Aug 9, 2004 | 04:28 PM
Infamous_Imports's Avatar
Default Re: (SOHC_MShue)
hmmm i wouldn't reccommend you hit it w/the sledge again...put some coke on it for a day or so n see how that works .
Old Aug 9, 2004 | 05:03 PM
Bailhatch's Avatar
Default Re: (Infamous_Imports)
Build yourself a breaker bar that bolts to the oil returm flange. I made one out of a piece of 1.5" black iron pipe and a 1"x1/4"x5" piece of steel stock welded to one end. Just drilled two holes in the plate that matched up with the drain flange and bolted it on real snug like. I put the turbo in the vise and have a friend hit the turbo end of the pipe while I pull. works great on those old T3s.
be careful if your try a real torch. I ruined a nice 50 trim saab once by getting it too hot with my oxy/acet torch with no oil to cool the bearings & seals. needless to say it didn't spin so hot afterwards. not really sure what I screwed up though, never took it apart. anyway, good luck!
Old Aug 11, 2004 | 09:21 PM
turboteg2nv's Avatar
Default Re: (Bailhatch)
[QUOTE=Bailhatch]Build yourself a breaker bar that bolts to the oil returm flange. I made one out of a piece of 1.5" black iron pipe and a 1"x1/4"x5" piece of steel stock welded to one end. Just drilled two holes in the plate that matched up with the drain flange and bolted it on real snug like. I put the turbo in the vise and have a friend hit the turbo end of the pipe while I pull. works great on those old T3s.
QUOTE]
I'm gonna try this. I've been having the same problem, it just won't move. time to get creative..
EG95D15VTEC
Jul 7, 2007 09:18 AM
Mr HYDE
Mar 14, 2007 08:39 PM
s2kc's
Mar 2, 2005 11:43 PM
singlecamcrx
Nov 22, 2004 10:33 AM
Turbocivic94
Oct 15, 2004 09:57 AM
