Buying a turbo and need help!!!
Old Mar 2, 2005 | 06:21 PM
s2kc's's Avatar
Default Buying a turbo and need help!!!
Hi all, Im buying a turbo from a guy on a local forum and wanted to see if there was any tips you can give me on spotting if it's a good turbo or not. I'm basically wondering if there are any obvious things i would notice if it was a bad turbo. Hope you can help. BTW it is a garret t3/t4. Thanks!!
Old Mar 2, 2005 | 06:23 PM
DefiantGSR's Avatar
Default Re: Buying a turbo and need help!!! (redb20teg)
shaft play in and out means the turbo is fucked. shaft play side to side if ok as long as it is very very minimal.
Old Mar 2, 2005 | 06:41 PM
s2kc's's Avatar
Default Re: Buying a turbo and need help!!! (DefiantGSR)
so if i pull out or push in it shouldn't move? if it does, thats a problem right?
Old Mar 2, 2005 | 08:47 PM
oxSLEEPERxo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redb20teg &raquo;</TD></TR><TR><TD CLASS="quote">so if i pull out or push in it shouldn't move? if it does, thats a problem right?</TD></TR></TABLE>
yea, just check for shaft play. side to side should be a tiny bit, when there is only in it, it should tighten up. Pulling in or out, should be minimal to none. Make sure the blades haven't be scrapping the sides
Old Mar 2, 2005 | 09:26 PM
s2kc's's Avatar
Default Re: Buying a turbo and need help!!! (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">
yea, just check for shaft play. side to side should be a tiny bit, when there is only in it, it should tighten up. Pulling in or out, should be minimal to none. Make sure the blades haven't be scrapping the sides</TD></TR></TABLE>
thanks alot guys!
Old Mar 2, 2005 | 11:43 PM
s2kdre's Avatar
used turbos are no good if they've been sitting for a while. Cause the front seal dries out.
D17alltheway
Honda Civic (2001 - 2005)
Mar 20, 2008 08:22 PM
JLAO
Feb 6, 2007 12:07 AM
jdmxxdc2
Apr 11, 2005 11:27 AM
hiimdaviddd
Mar 27, 2005 02:48 AM
CalvitoSol
Jun 12, 2002 05:58 PM
