B16 turbo project
Old Nov 6, 2003 | 01:17 PM
dwilson's Avatar
Default B16 turbo project
Im starting a new turbo project and was wanting to get a couple of pointers. I have already purchased a set of 10:1 pistons and a set of Crower billet rods. My goal will be to have a 400whp street car. What Im wondering about is the stock sleeves in the B16, will they stay together under the amount of boost i am going to have to run to get to this goal. I am not willing to resleeve the block, so im just wondering if i am setting my goal a little high. If someone would share some info of some experiences i would appreciate it. Thanks
Old Nov 6, 2003 | 04:44 PM
dwilson's Avatar
Default Re: B16 turbo project (dwilson)
TTT
Old Nov 6, 2003 | 05:16 PM
Mohudsolo's Avatar
A fellow autoxer had a GSR with a JRSC with the high boost pulleys. He said 230-250whp, I never saw a dyno so can't say. He had it for around 4 years then this year determined the bores were oval to the point of needing a rebuild. He went the easier way and went back to a stock motor with a new shortblock and got rid of the SC.
For the power level you are looking for you will need some serious boost. I can't see the stock sleeves taking that much boost and staying round. I would guess the people in the FI forum could give better advice than me.
Old Nov 6, 2003 | 06:00 PM
dwilson's Avatar
Default Re: B16 turbo project (Mohudsolo)
Yeah i think i will post this over there and see what they can tell me. Anyways thanks for the advice.
Old Nov 9, 2003 | 04:38 PM
iwhichisme's Avatar
10:1 seems kind of high for turbo, and 400 whp w/o resleeving wont last every long if its possible. there are so many factors that must be included into the equation when talking about that kind of power from turbo.
Old Nov 9, 2003 | 05:29 PM
dwilson's Avatar
Default Re: B16 turbo project (iwhichisme)
so i guess that i should include a thicker head gasket to lower compression and shoot for around 350 horse. the 400 horse was not a set in stone goal. i am just trying to get everything straight before i build this motor so that im not disappointed with my set up once i get it built .
Old Nov 12, 2003 | 01:13 AM
b18jdmteg's Avatar
400 can't be made with a stock block under boost you would half to maybe stroke the motor out to a 1.8 or a 2.0 and have new sleves put in , or even go with a closed deck setup , and make sure you go with a good set of forged pistons , for some reason people are under the impression that you half to have low compression to make good numbers with a turbo car but that is false higher compression with a good forged piston is going to pull better numbers
Old Nov 12, 2003 | 07:46 AM
ykracing's Avatar
Default Re: B16 turbo project (b18jdmteg)
your goal is not likely to happen... thats not to say that it isnt possible... but it isnt likely...
I managed to get 325-ish on a completely stock b16, and ran it all season... but I was running race gas, and had a 3" exhaust dump. You need all of the help you can get, and the exhaust is a big part of that....
just my two cents...
mx125cc
Jun 1, 2014 05:25 PM
91 DA Revived
May 19, 2012 04:11 PM
B16DA517
Jan 13, 2011 07:28 AM
Coolero
23
Dec 10, 2009 02:55 PM
ITRBOY1433
Oct 10, 2008 03:54 PM
