Tuning Question - Pump gas and Timing
Old Feb 20, 2004 | 10:43 AM
  #26
b18b1hmtlove's Avatar
Default Re: (Evo Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evo Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Cut that in half is what I run on my car. </TD></TR></TABLE>
If you run .45 degrees retard per psi on 93 octane at 15psi you are far braver than i would ever be
Old Feb 21, 2004 | 04:45 AM
  #27
b20turboic's Avatar
Default Re: (b18b1hmtlove)
i run .3 - .35 per pound till 10 on my b20 , that will still add up to 3.0 - 3.5 degrees pulled at 10 psi then i use a more linear approach to get the timing safe. Its a B20 you know haha runs like a raped ape
i dont know if you guys know but stock turbo cars dont even pull timing till 2-5 pounds then it starts to pull. But then again if the motor knocks in lets say a dsm it pulls like 10-15 degrees out but a honda w/ knock sensor will pull 2-3 max that = boom. also the larger your bore the more timing you actually need to make a complete combustion cycle. so my b20 actually requires more timing then an ls to fire correctly id say max .5 on my b20 while the ls motor is closer to .75- 1 degree pulled max or else the cars will show low hp and bog like a pos
Old Feb 21, 2004 | 01:27 PM
  #28
kpt4321's Avatar
Default Re: (b20turboic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic &raquo;</TD></TR><TR><TD CLASS="quote">i dont know if you guys know but stock turbo cars dont even pull timing till 2-5 pounds then it starts to pull.</TD></TR></TABLE>
Not necessarily true. In a stock turbo car, the timing is jst a curve; thus, there is no point where it "starts to pull." Usually you have like, close to 40 degrees at very low load (light cruise) and then a gradual curve down to around 20 degrees at WOT. In between it's just between the two as you would expect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">But then again if the motor knocks in lets say a dsm it pulls like 10-15 degrees out but a honda w/ knock sensor will pull 2-3 max that = boom.</TD></TR></TABLE>
That is a very good point. The knock sensing systems on Hondas are simply not engineered or programmed to cope with the high cylinder pressures of a turbo car (if they were, it would suck for NA, which they ARE designed for!)
Old Feb 21, 2004 | 05:47 PM
  #29
D@nnY's Avatar
BIGGER DISPLACVEMENT CALLS FOR MORE TIMING OR THE CAR WONT RUN RIGHT. AN H22 NEEDS MORE TIMIGN THAN A B16 AT THE SAME BOOST.
Old Feb 21, 2004 | 06:00 PM
  #30
Cyphear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic &raquo;</TD></TR><TR><TD CLASS="quote"> a honda w/ knock sensor will pull 2-3 max </TD></TR></TABLE>
to you, honda's pull 12 degrees and give one degree back every second for the next twelve seconds.
550whpcivic
Engine Management and Tuning
18
Aug 12, 2011 01:43 PM
GReddy SI
Oct 21, 2004 07:56 AM
Turbowa
Aug 27, 2004 06:08 AM
tolowhb
Feb 21, 2004 10:24 AM
Aeka GSR
Mar 12, 2003 07:47 PM
