which tuning program to use?
Old Aug 15, 2007 | 06:07 PM
  #51
92hatch_cx-t's Avatar
Default Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">You weren't able to find anything when searching for DSM 450 or for Motorola 2.5 bar?</TD></TR></TABLE>
yeah i found the dsm injectors but i wanna know if the motorola 2.5 bar is good or not. the guy says it works but i want to hear from some that actually has used it
Old Aug 15, 2007 | 06:39 PM
  #52
Joseph Davis's Avatar
Default Re: (92hatch_cx-t)
I've used several dozen of them, they do not suck. Best cheap MAP sensor ever.
Old Aug 17, 2007 | 05:05 PM
  #53
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">I've used several dozen of them, they do not suck. Best cheap MAP sensor ever.</TD></TR></TABLE>
oh ok thanks
Old Aug 20, 2007 | 04:26 PM
  #54
should i use the same gap as factory spark plugs or use a different gap?
Old Aug 20, 2007 | 08:23 PM
  #55
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatch_cx-t &raquo;</TD></TR><TR><TD CLASS="quote">should i use the same gap as factory spark plugs or use a different gap?</TD></TR></TABLE>
You will need spark plugs with a colder heat range along with a smaller gap.
The exact plug/gap depends on your application.
Old Aug 20, 2007 | 10:38 PM
  #56
Default Re: (mtber)
yeah i did get colder spark plugs but not sure bout the gap
Old Aug 27, 2007 | 10:24 PM
  #57
what would happen if i put the dsm injectors? would it run way to rich? or it wouldnt even run. i dont really wanna drive like an hour and a half just to get a base map but ill do it if i have to. if my car will run ill just drive it there...
thanks
A BOOSTED CRX
Mar 28, 2008 04:25 PM
skUnK2jdm
Dec 2, 2007 05:21 PM
vg7z
Sep 12, 2006 07:20 PM
94_CRVtec
May 17, 2005 09:28 PM
zbower7
Jul 13, 2004 07:23 AM
