440 inj question
Old Dec 1, 2007 | 03:41 PM
skUnK2jdm's Avatar
Default 440 inj question
iam curently running 8 lbs of boost on my b16a with a t3/t4, and i want to turn up the boost to 14 psi! can my dsm 440s handle that?
thanks
Old Dec 1, 2007 | 04:26 PM
skUnK2jdm's Avatar
Default Re: 440 inj question (skUnK2jdm)
Old Dec 1, 2007 | 04:44 PM
xenocron's Avatar
Your stock map sensor can't...
And you'd really be pushing the DSMs
Old Dec 1, 2007 | 05:09 PM
JaredKaragen's Avatar
Default Re: 440 inj question (xenocron)
lolz, dsm's didn't put out a 440cc anyways; but xenocron is correct... partially;
it depends on your BSFC, your fuel system, and your turbo trim/specs.
And; yes; you would need a new MAP.
Old Dec 1, 2007 | 06:50 PM
skUnK2jdm's Avatar
Default Re: 440 inj question (JaredKaragen)
ok so will a missing link fix the map sensor problem? and what cc injector would i need for a t3/t4 .50 trim?? thanks!!
and whats a bsfc??
Old Dec 1, 2007 | 08:10 PM
93CX's Avatar
No, you need a map sensor that can read above 10.5 psi. GM 3 Bar MAP is what people typically use on this board. And for the injectors, 750cc will give you some growing room. No reason not to go big
Old Dec 1, 2007 | 08:39 PM
skUnK2jdm's Avatar
Default Re: 440 inj question (93CX)
i now have the dsm blue top injectors what cc are those?
Old Dec 1, 2007 | 08:59 PM
lakai_19's Avatar
450cc
Old Dec 1, 2007 | 09:24 PM
skUnK2jdm's Avatar
Default Re: (lakai_19)
whats the most i can boost with 450cc??
Old Dec 1, 2007 | 09:39 PM
.CUBISH.'s Avatar
ur askin for trouble.. just bring the car by the shop and we'll do it the right way on the dyno.. if i remember correctly ur car has a 3 bar map on it already
u can get a little over 300 with the 450's
Old Dec 1, 2007 | 09:50 PM
skUnK2jdm's Avatar
Default Re: 440 inj question (.CUBISH.)
you know iam new to this turbo scene lol
ok ill be by there i also need to replace this turbo its a t3/t4 .50
lmk what you can get! and what will fit!
Old Dec 2, 2007 | 05:21 PM
SteamedRice's Avatar
is there a rule of thumb when thinking about the right injectors? i'm building a 2.0 gsr 9:1 fully built with a peak boost FTW kit... 660 maybe?
and another question,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">No, you need a map sensor that can read above 10.5 psi. GM 3 Bar MAP is what people typically use on this board. And for the injectors, 750cc will give you some growing room. No reason not to go big </TD></TR></TABLE>
can you go too big?
projectjazzmine
Engine Management and Tuning
Jun 10, 2008 09:38 AM
b16bri
Nov 18, 2007 04:18 PM
B16Civic93
Apr 2, 2005 09:39 AM
zbower7
Jul 13, 2004 07:23 AM
dominate9
Nov 15, 2003 01:01 PM
