Tuning Love
Old Apr 21, 2005 | 12:16 PM
  #51
RyanEJ8's Avatar
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't have anything to do with the zex cam. Truse me i've tested both the stock and zex cam and had to advance it all the way with both of them. It is just something that happens when you convert to obd1 on a y8. If you want to retard the cam timing more then just make sure you advance your ignition maps enough so that your base timing gets back to 12*. </TD></TR></TABLE>
I'm not too sure about that because I had done the OBDI conversion before the cam install and I didn't have a problem advancing the base timing more than 12 deg with the cam gear zeroed out.
Old Apr 21, 2005 | 01:27 PM
  #52
SOHC_MShue's Avatar
Default Re: (RyanCivic2000)
well did you have your timing in hondata set to a base of 16* in the maps and then have your distributor set to 12? That could explain it. Also did you have to advance the dizzy at all?
Me and numerous other people have had to advance our distributors all the way to get to the proper base timing after converting to obd1. Some include BlackCRX and luti from over on the uber forums.
EG-SIXV-TEC
May 11, 2009 03:00 PM
hondafan62269
Jan 7, 2005 09:34 PM
EtotheG
Nov 6, 2003 08:40 AM
Civic_95_Si
Oct 24, 2002 01:09 PM
r30slick
Nov 24, 2001 09:54 PM
