Cam Timing And Forced Induction
Old Oct 24, 2002 | 11:43 AM
Civic_95_Si's Avatar
Default Cam Timing And Forced Induction
I have a cam gear on my D16Z6. I also plan to turbo over the winter. How will cam timing effect the engine under boost? I have it advanced about 6 degrees right now. Will it make it any more or less prone to detonation either way? I'm still usuing the stock cam.
-Jeff
Old Oct 24, 2002 | 11:44 AM
TeStUdO's Avatar
Default Re: Cam Timing And Forced Induction (Civic_95_Si)
more prone, retard the timing.
Old Oct 24, 2002 | 11:51 AM
Default Re: Cam Timing And Forced Induction (00si5)
OK one note..I'm not talking about ignition timing. I know that has to be retarded. Cam timing has more to do with moving the power band around and the way it flows.
Old Oct 24, 2002 | 12:54 PM
ion_four's Avatar
I don't think it would make MUCH difference in how prone you are to detonation...it will however bring in more or less air, depending, and thus make you more rich or lean. Which way it goes? I couldn't say, but Dyno could
Old Oct 24, 2002 | 01:09 PM
niedejb's Avatar
Default Re: Cam Timing And Forced Induction (ion_four)
I have a sohc and the dyno said 0 degree offset was the most powerful.
Sorry its in excel, but here it is @ 10 psi
[Modified by niedejb, 4:22 PM 10/24/2002]
Red_Si
Apr 20, 2004 07:21 PM
Lazydsm
Feb 6, 2003 06:47 AM
Jockobo
Jan 23, 2003 03:48 PM
redcxhatch
Nov 16, 2002 08:04 AM
eargrub
May 16, 2002 11:00 AM
