timing question
Old Dec 24, 2004 | 09:11 PM
94ta_lt1's Avatar
Default timing question
hi, i have a d15b7 that i am turboing. I am going to be running around 7psi. I don't have the msd boost/timing controler that retards the timing for every pound of boost. How should i set my timing?? thanks
Old Dec 24, 2004 | 09:21 PM
W O T's Avatar
Default Re: timing question (94ta_lt1)
by retarding the dizzy lol
If your gonna get the car tuned, your tuner will do it easily, depends on how much psi you wanna run and the octane of gas your gonna use
Old Dec 24, 2004 | 09:32 PM
teal EJ1's Avatar
Default Re: timing question (W O T)
what are you going to run for fuel management?
Old Dec 24, 2004 | 09:45 PM
highmilehatch's Avatar
The type of fuel management kind of determines the answer. If you have full control of the fuel and ignition maps via standalone, you can edit the ignition values in the boost section of the map. If you don't, and are maybe just running an fmu and 7 psi off the wastegate spring, set the distributor to 14 degrees BTDC. This will take out 2 degrees across the board. I would consider that totally safe.
Old Dec 24, 2004 | 10:49 PM
94ta_lt1's Avatar
Default Re: timing question (highmilehatch)
93 octane, safc with dsm injectors. i was planing on setting the timing to 12-14 btdc...i know you have to turn the dist. but i haven't ever timed a honda before..just v8s manily lol. On hondas, where do you look for the tming marks and is 14 btdc marked on there?? thanks
Old Dec 24, 2004 | 10:55 PM
Off the top of my head, either the mark to the left or right of the center mark (16 degrees) is 14 degrees. It's late. I should be sleeping.
Old Dec 25, 2004 | 03:45 PM
94ta_lt1's Avatar
ok, maybe i can call honda up and ask them. thanks
CRXLST
Oct 27, 2004 09:45 PM
B_1_8_hatch
Jul 28, 2003 01:33 PM
wzcb08
May 19, 2003 07:47 PM
madman604
May 9, 2003 05:57 PM
deacs
Oct 11, 2002 09:33 AM
