Timing question
Old Oct 11, 2002 | 06:27 AM
deacs's Avatar
Default Timing question
What would happen if i retarded my timing slightly too much on My FI civic??? im running the full AFC hack and get detonation at over 8psi?? im running NGKR7E plugs, 255lph in tank, 450cc's S-AFC set at -33%
I have trouble starting the car sometimes and i have read the blue wire voltage( o2 sensor) at WOT at 8spi (when it detonates) and im getting 0.91 to 0.92 V which surely means its running plenty rich enough????
I wondered if the detonation was due to over retarded timing???
Old Oct 11, 2002 | 06:35 AM
brian b's Avatar
New User
Default Re: Timing question (deacs)
too little timing can cause high combustion chamber heat.. how many degrees are you running at what rpm & boost?
Old Oct 11, 2002 | 09:33 AM
deacs's Avatar
Default Re: Timing question (brian b)
Static timing set at roughly 10 degrees, 9 psi boost wanted.
Would too far retarded timing account for my bad starting and pinking at 9psi??? also im in the UK and pump gas here is 98 octane so surely i shouldnt really be getting pinking with my set up???
Surely is gotta be timing related?
wzcb08
May 19, 2003 07:47 PM
SSBP DC2
Mar 2, 2003 10:47 PM
b00stedbyFastrax
Sep 1, 2002 06:39 AM
Jared
Aug 28, 2002 10:12 AM
