Timing on JRSC?
Old Nov 9, 2005 | 01:27 PM
E-gg's's Avatar
Default Timing on JRSC?
I have a JRSC on my 94 SOHC VTec Si. I am wondering if I need to change the timing or I should keep the factory timing? Any input? Thanks.
Old Nov 10, 2005 | 12:45 PM
justinb18c's Avatar
Default Re: Timing on JRSC? (E-gg's)
do you have any engine management? If not, yes you will need to retard the timing. I think I have it retarded bout 10 degrees, and im running a stock JRSC on a gsr. you will run into a prob with pre-denotation if you dont retard the timin.
Old Nov 10, 2005 | 12:52 PM
s2kdre's Avatar
Default Re: Timing on JRSC? (justinb18c)
10 or 11 degrees at the distributor is fine
Old Nov 11, 2005 | 05:35 PM
E-gg's's Avatar
Default Re: Timing on JRSC? (jdmhonda)
Thx. I gotta check it out tomorrow morning.
Old Nov 14, 2005 | 06:49 AM
hondaeg8's Avatar
do you have the JR map mod?
i'm using the JR map mod on my gsr motor and i have my timing set back one degree running 6psi. so mine is set at 15BTDC. setting it at 10BTDC makes your car run like *** IMO.
i use 93 octane though
2K Teggy
Nov 4, 2003 04:02 PM
MartyMarGSR
Apr 2, 2003 07:35 AM
Replica
Sep 10, 2002 08:36 AM
SCsol
Jun 15, 2002 11:29 PM
HybridMT
Jul 1, 2001 10:56 AM
