timing and EGT's
Old Sep 21, 2002 | 10:48 AM
DIRep972's Avatar
Smarter than you
Default timing and EGT's
how much will retarted the timing 5 degrees effect the EGT readings?
reason I ask is because on my old FMU set up and stock timing at 7psi id see 750degrees. If i was boosting and it ever went above 780 id let off immediatly. Now my EGT's climb to 810degrees immediatly and I guess im just a lil scared seeing that # and I want to make sure its ok.
Old Sep 21, 2002 | 08:37 PM
Blaze45's Avatar
Brrraaaap!
Default Re: timing and EGT's (DIRep972)
bump cause i would like to know as well
Blaze
Old Sep 21, 2002 | 10:48 PM
PureTeg420's Avatar
I retarded my timing about 5 degrees and my egt's went up about 50-75 degrees higher. So I got close to 800 at full boost. this was running an 8:1 FMU w/ 310's.
[Modified by PureTeg420, 11:48 PM 9/21/2002]
Old Sep 21, 2002 | 10:51 PM
inspyral's Avatar
http://www.sdsefi.com/techegt.htm
Old Sep 21, 2002 | 11:48 PM
zojirushi's Avatar
Default Re: timing and EGT's (inspyral)
i get around 820 c at full boost with 14" timing.
Old Sep 22, 2002 | 11:16 AM
BoostedED9's Avatar
Default Re: timing and EGT's (zojirushi)
the more you retard timing hte higher the temp's will go.... what is the limit on honda's???
Old Sep 22, 2002 | 11:24 AM
b18c5turbo's Avatar
Default Re: timing and EGT's (ED9Hybrid)
i would not go over 800 whit stock piston and stock valve
ive seen 850c at wot but i was playing whit fire(stock valve whit forged piston)
Old Sep 22, 2002 | 02:29 PM
ion_four's Avatar
Default Re: timing and EGT's (b18c5turbo)
isn't it the case that as egt's go up that cylinder temps go up, since it's letting some of the burn out before it's done? If so, then higher egts would be better for stock engines, to a point?
spoolingb20
Apr 26, 2006 10:46 AM
c-way
Jun 11, 2004 04:16 AM
B_1_8_hatch
Jul 28, 2003 01:33 PM
wzcb08
May 19, 2003 07:47 PM
wrXtian
Mar 25, 2003 03:55 PM
