timing questions
Old Mar 24, 2003 | 10:42 PM
wrXtian's Avatar
Default timing questions
i was reading about timing.. and stock is supposed to be around 16.. and it says the car can run safely + or - 2 degress from 16 so i guess a 14, and a 18 are attainable safely.. i want to retard my timing in my integra on boost, and i was curious if i retard it more than 14 btdc will it damage the car? after reading this i thot maybe i'll jst have my timing set to 14.
Old Mar 24, 2003 | 10:56 PM
intekragsr's Avatar
Default Re: timing questions (xjdm94x)
dunno, but I got a bump for u Christian.
If you need help doing your timing, I can do it for you since I just bought my advance timing gun. I have to return it in like 10 days though
Old Mar 25, 2003 | 12:06 AM
allbottleb16's Avatar
Default Re: timing questions (intekragsr)
NO, you can actually pull alot more timing out then that. On my car I pull 2deg per pound of boost(8psi=16deg), and i run around 14-16 deg. of base.
Old Mar 25, 2003 | 07:06 AM
EVIL_AWD's Avatar
Default Re: timing questions (allbottleb16)
Your base timing should be set at 16 degress +/- 2 degrees, but under boost you will want to pull timing on a per pound basis. If you're not running an engine management system that allows you to adjust your fuel and timing parameters I would recommend a MSD BTM which will allow you to pull timing as the boost builds.
Old Mar 25, 2003 | 07:26 AM
Pengo's Avatar
2 deg per psi? isn't that a little extreme? how much boost are u running?
Old Mar 25, 2003 | 07:49 AM
wrXtian's Avatar
Default Re: timing questions (Pengo)
hmm.. i was thinking maybe 1 degree or .5 degrees per pound of boost..
Old Mar 25, 2003 | 08:09 AM
Flamenco-T's Avatar
DAMN, are you sure ? you're pulling WAYYY too much timing per pound of boost...
you're basically at zero timing if not...
you can pull .5 to .7 deg per pound of boost. Depending on your CR rate, most of LS with 9.2:1 CR, you cna get away with stock timing ~16 deg, for most GS-R, you cna retard about 2-3 deg if you're running 6-8 psi daily...
loosing too much timing will cause your car to run liek **** at vacuum
stan
Old Mar 25, 2003 | 08:24 AM
b16ahybrid's Avatar
Default Re: timing questions (Flamenco-T)
stan
thats the great thing about the btm ....stock timing under vacuum and retarded as boost goes up...
but yeah 2 degrees per psi seems a bit much....but if thats what it takes..
Old Mar 25, 2003 | 08:29 AM
Flamenco-T's Avatar
Default Re: timing questions (b16ahybrid)
BTM is good if you're gonna run on FMU for a while, other than that, just retard 2-3 deg until you get a standalone or anything to manage timing under boost and leaving it stock at vac.
stan
Old Mar 25, 2003 | 09:00 AM
GruvyTune's Avatar
New User
i'll let you all in on a little secret... (ps. i learned this one from Sonny)
If you have a hondata unit or similar, change the rate of timing cut.
ie. from 0-4psi boost, cut only 0.2 deg / psi boost; from 4-8psi cut 0.4deg/psi; from 9-11psi cut 0.5-0.6 deg/psi. from 11psi up, just keep the same timing as you have for 11psi.
now, there are some other little tricks I won't discuss. But, that will let you noobie tuners and perhaps some more experienced tuners quite a bit more HP and torque in the lower areas of boost!
Old Mar 25, 2003 | 03:48 PM
Default Re: timing questions (GruvyTune)
I pull alot of timing because i tune on pump gas( daily driver).
I figure i will add a ton more timing , once i get it on the dyno and have my J&s safeguard.
knock is your enemy.
Old Mar 25, 2003 | 03:50 PM
Mase's Avatar
id say on average, people take out .7 degrees per psi
Old Mar 25, 2003 | 03:55 PM
boostaholic's Avatar
Even on if you tune for pump, 2 degrees per psi is too much retard. Usually .5 - .7 degrees per psi will net good numbers.
93lsv_turbo
Apr 15, 2011 12:08 PM
turbo-crx
May 18, 2008 02:13 PM
mortificationrock
Jul 10, 2007 04:26 PM
spoolingb20
Apr 26, 2006 10:46 AM
wzcb08
May 19, 2003 07:47 PM
