Is this block sleeved?
Looking at buying an LS.
Was told its Darton sleeved with a block guard. I have terrible eyes. From pics, looks like Honda Sleeved with a block guard. Wanted some better eyes to check it out.
On to pics:
On to pics:
Re: Is this block sleeved?
they are def stock honda sleeves.. there is a darton rep on the site.
these are there sleeves that have the "stock" look.
http://www.google.com/imgres?imgurl=...&tx=100&ty=138
and look how much thicker they are stock.
Crazy Honda Guy
Darton sleeve kits i've sold for Honda block had their own block guard and look different slightly.....the one you pictured doesn't look right
Check this link out, this is what i mean.....
http://www.exospeed.com/store/index....11_259_260_261
thats what im saying it doesnt seem right and the walls look wayyyyy to thin to be sleeves.
i would throw it to the wind. whats the dude asking for it.
Looks like stock sleeves. It may have thin wall lining sleeves. Usually you would see a slight bevel around the top of the sleeves on the thin wall lining type sleeves.
Incorrect as usual... You don't know what a stock block looks like? Check the shop I'm sure someone can show you. You can knock these sleeves all you want like you did in another thread but they are the same sleeves Dart uses in their Honda blocks which we supply them.
The stock sleeves do not touch each other between the cylinders. Those actually look like the 300 series sleeves. It hard to tell by the pick but the sleeves slightly over lap each other between the cylinders. Since the flange is a little bigger than bore center the sleeves are installed staggered, #1 and #3 first and when you cut for #2 and #4 it makes a slight relief in the flange so they touch.
Hmmm. I can buy an AEBS 84mm sleeved at the highest price
Or Eagle sleeved 85mm w GSR water pump Itr oil pump with eagle rods for sAme price as AEBS
or this LS that's 81mm plus eagle rods for less than both...
I want some very definite confirmation on this being sleeved.
