Is this block sleeved?
Old Jan 8, 2010 | 09:52 PM
2LiterTurboSeR's Avatar
Default Is this block sleeved?
I'm in talks with a guy about picking up this block, he says it is a Darton Sleeved B18C1. I'm not familiar with engine blocks so I wasn't sure if it is sleeved or just has a block guard installed. Just wanted to make sure before I make the drive to look at it.
Also, he says he melted a piston before but a machine shop said the cylinder walls were still ok. Claims the block is 84mm, but if it does have damage to the walls can they be bored over? I'll be taking a bore scope with me just to check. Pics:
Thanks in advance!
Old Jan 8, 2010 | 09:54 PM
dc2luver's Avatar
Default Re: Is this block sleeved?
yes indeed it is sleeved. And if the walls are damaged yes it can be bored over.
Old Jan 8, 2010 | 09:56 PM
reactiondc2's Avatar
truth
Old Jan 8, 2010 | 10:44 PM
king06's Avatar
Looks like AEBS sleeves
Old Jan 9, 2010 | 05:36 AM
Boosted-EH-804's Avatar
AEBS sleeves
Old Jan 9, 2010 | 05:58 AM
jdm inc's Avatar
x2
Old Jan 9, 2010 | 07:15 AM
4drdohc's Avatar
my darton sleeves closed deck looked like that, but the holes were smaller, that does indeed look like aebs
Old Jan 9, 2010 | 10:20 AM
EFPhilly's Avatar
I wish I had oil jets
Old Jan 9, 2010 | 11:08 AM
tofast4uh22's Avatar
make sure he has the matching main caps to go with it!!!!!!!
Old Jan 9, 2010 | 11:35 AM
cjordan's Avatar
i was going to say that myself!! also, those look like AEBS sleeves.
Old Jan 9, 2010 | 02:05 PM
Yes sir, all inclusive with main caps, crank and oil pan.
Thanks for all the help guys, I'm getting a hell of a deal!
Old Jan 9, 2010 | 02:29 PM
h2.4's Avatar
I don't think the cooling holes are drilled from the factory. Usually the machinist drills the cooling holes when done installing. Regardless , op, just measure and overbore if needed. Hopefullly they aren't leaking.
dimo92
Dec 16, 2013 07:05 AM
TravisBiggie
Oct 18, 2013 05:08 AM
dc2_poojan
Jun 8, 2012 07:02 AM
Rickcrx
Feb 23, 2012 05:18 PM
phiberoptik
Oct 29, 2003 11:58 AM
