ticking noise at boost
Old May 23, 2006 | 06:53 PM
teddy_dc2's Avatar
Default ticking noise at boost
i get thins ticking noise when i hit boost, i don't know what it is or where's coming from, sounds like from front of car, gets louder with more boost. i recently welded a new a flex pipe but i had this before. now it's louder.
Old May 23, 2006 | 06:55 PM
boostismycrack's Avatar
E-thug
Default Re: ticking noise at boost (teddy_dc2)
could be detonation could be exhaust leak could be stepper motor for ebc, need 2 b more specific.
Old May 23, 2006 | 07:46 PM
teddy_dc2's Avatar
i was told my throw out bearing is going bad but i think it would make a big noise when accelerating, not at boost.
Old May 23, 2006 | 09:21 PM
Jay_Sensing's Avatar
This sounds off the wall but you aren't running an electronic boost controller are you?
Old May 23, 2006 | 11:49 PM
GsR92HaTcH's Avatar
throw out bearing would be all the time.. except when clutch is engaged...more specific
Old May 24, 2006 | 07:50 AM
teddy_dc2's Avatar
we went fishing 40 min drive from home and 40min back, i was beating it a few times to see if boost and all was normal. on the way back it started making that noise only at boost with a few loud backfire at vac but i've heard that noise in recent times, not always. car is untuned on fmu, all stock fuel except for walbro intank. this morning i took it out for a spin and ran fine without the noise or backfires. could it be the oil pressure or too hot? put 4.5 qt 10w30 a while back. my friend says the car is not getting enough fuel or when it does, too much.
Old May 24, 2006 | 07:55 AM
wpgcivic's Avatar
sounds like detonation to me
Old May 24, 2006 | 07:56 AM
teddy_dc2's Avatar
no boost controler yet, just 5psi off the compressor housing. throwout bearing pitch is the same through out all gears but noise goes away when clutch pedal is pressed to engagement point. couldn't it bee not enough oil and rings scraping? not engine light either.
Old May 24, 2006 | 09:56 AM
Sounds like detonation to me as well.
I said boost controller because all the EBC's I have had have a very loud solenoid and a lot of people think something is broke when the car crosses from vacuum to boost and you can here the solenoid start raising hell.
Do you happen to have an EGT gauge in the car and notice what the temps were getting to?
Old May 24, 2006 | 10:38 AM
teddy_dc2's Avatar
i only have a boost gauge, been running the oil for about 2k now. engine temp is fine. could it be oil pressure/temp too high?
Old May 24, 2006 | 11:22 AM
ccivic's Avatar
Default Re: (teddy_dc2)
No. You're probably detonating in boost-- not enough fuel, or too much timing. Junk the FMU and get it tuned.
Old May 24, 2006 | 11:45 AM
sp00led's Avatar
Default Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">No. You're probably detonating in boost-- not enough fuel, or too much timing. Junk the FMU and get it tuned.</TD></TR></TABLE>
Old May 24, 2006 | 12:58 PM
I got a honda's Avatar
Default Re: (sp00led)
does it sond like when you put water based foods on a pan of oil when you cook? it makes that ticking/weird/cracking noise?? if so i had that on my boosted gsr and it was def detonation....then id put 100 octane in it and it go away...
Old May 25, 2006 | 11:04 AM
teddy_dc2's Avatar
yes
Old May 25, 2006 | 11:39 AM
mike1114's Avatar
I recall reading you still have stock injectors and an UNTUNED motor.
I wouldn't boost on this until you get it tuned with some better injectors, as all have said before, probably detonation if it doesn't do it at idle and cruising also.
boostedd16z6
Dec 26, 2007 03:05 PM
Damion W
Jun 28, 2005 08:54 PM
asianspeed
Mar 4, 2003 06:53 AM
yellowbulbs
Jul 8, 2001 09:24 AM
