sputtering problem
Old Jul 29, 2008 | 06:14 PM
EG6_978's Avatar
Default sputtering problem
got a stock z6 wid a greddy turbo kit . everytime i speed it feels like its boggen out . then the check engine light turn on .i got a tuned ecu by phearable.net . wen i use my frends s300 everything ok. cud it be a map sensor . or shud i get a s200
Old Jul 29, 2008 | 06:32 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: sputtering problem (EG6_978)
could be, a little more info would be nice.
check engine light turning on? how is the map set up on the phearable? did he set it to go in limp mode at a certain rpm? too many ?marks
Old Jul 29, 2008 | 06:41 PM
EG6_978's Avatar
Default Re: sputtering problem (HybridcivicLS-T)
the map sensor in the ecu is tuned to read 11 psi. im only running 7psi. I dont kno all the details of the ecu because i bought it off a frend. im not sure what limp mode means either. it sputters in 1st n 2nd gear around 4 or 5grand
Old Jul 29, 2008 | 06:43 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
so you havent acutally been tuned?
probably leaning out like crap. Im guessing you dont have a wideband as well.
Old Jul 29, 2008 | 07:09 PM
EG6_978's Avatar
nope just slap the turbo on a couple days ago and i didnt get a wideband yet. what do u think i should do or get to fix the problem and make it faster
Old Jul 29, 2008 | 07:20 PM
FastEg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_978 &raquo;</TD></TR><TR><TD CLASS="quote">nope just slap the turbo on a couple days ago and i didnt get a wideband yet. what do u think i should do or get to fix the problem and make it faster</TD></TR></TABLE>
Park it until you get it tuned before you mess anything els up.
Old Jul 29, 2008 | 10:44 PM
mtber's Avatar
Default Re: sputtering problem (FastEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastEg6 &raquo;</TD></TR><TR><TD CLASS="quote">
Park it until you get it tuned before you mess anything els up. </TD></TR></TABLE>
1. Is the check engine light on? If so, read the codes & get back to us :-)
2. Did you gap the plugs properly? Are you running the proper spark plugs?
3. Are you using a wideband to monitor your air fuel ratios? If not, don't drive the vehicle under full throttle conditions.
4. Contact phearable.net directly for further technical support if needed.
Old Jul 30, 2008 | 06:08 PM
EG6_978's Avatar
Default Re: sputtering problem (mtber)
i took out the catylitc converter and it felt so much better but it sputters but not as bad as before i got ngk plugs i didnt get a wideband yet but planning on to get one. how much do they go for?
Old Jul 30, 2008 | 08:19 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_978 &raquo;</TD></TR><TR><TD CLASS="quote">i took out the catylitc converter and it felt so much better but it sputters but not as bad as before i got ngk plugs i didnt get a wideband yet but planning on to get one. how much do they go for?</TD></TR></TABLE>
They start at $199.99 for an innovate lc-1 without a gauge and go up from there.
Old Aug 3, 2008 | 01:52 PM
EG6_978's Avatar
i was wondering if all the pherable ecu comes with vtec. and does the vtec not working can cause the problem or to little boost or too much
Old Aug 3, 2008 | 05:56 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_978 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if all the pherable ecu comes with vtec. and does the vtec not working can cause the problem or to little boost or too much</TD></TR></TABLE>
Phearable.net ecus come programed for what the customer orders.
vietrob1037
Sep 17, 2009 03:58 PM
eg2tr
Jan 5, 2008 09:36 PM
turboedd15b
Jul 18, 2005 07:58 PM
turbosi03
Jan 21, 2004 08:04 PM
hybrid901
Jun 16, 2003 05:13 AM
