B16 Transmission VS. GSR Transmission
I have a 1992 Honda Civic DX Hatchback. (Weight = 1970)
I have a B18a1 motor in it right now with a B16 tranny. In a weeks time i am going to put a turbo on the motor and boost 10psi. I wanted to know which tranny would make the car faster a B16 or a GSR on this setup?
PS: I have a GSR tranny at my house.
Re: B16 Transmission VS. GSR Transmission (b20vcrxsir)
you'll have faster qaurterr mile times with the b16 tranny (shorter gears), sux driving on the high way, but u can always change that 5th gear with gsr's 5th gear.
b16 for racing, gsr if you are on the freeway a lot. I just changed my tranny to gsr and the b16 was a hell of a lot faster getting up, but i couldnt stand being at 4k+ on the freeway
Re: (Topdawgg)
this thread is full of fail! the OP is asking which tranny will be FASTER and the answer to that is the one with the shorter gearing which would be the B16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vcrxsir »</TD></TR><TR><TD CLASS="quote">I have a 1992 Honda Civic DX Hatchback. (Weight = 1970)
PS: I have a GSR tranny at my house.</TD></TR></TABLE>
the b16 will defiantely be faster, but on a side note i thought the 92 hatchback cx was the lightest model unless of course you have some weight reduction....
Re: B16 Transmission VS. GSR Transmission (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">
the b16 will defiantely be faster, but on a side note i thought the 92 hatchback cx was the lightest model unless of course you have some weight reduction....</TD></TR></TABLE>
wrong the vx is the lightest
Yes, I had a lot of weight reduction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike »</TD></TR><TR><TD CLASS="quote">
wrong the vx is the lightest </TD></TR></TABLE>
ah your right! according to this:
http://sportcompactcar.automot....html
only by about like 14lbs! lol
Sorry not trying to thread jack, but just a quick question. I have two B16 trans one with a LS 5th. I'm assuming the one with the LS 5th would be great for a 375-425whp DD. Correct?
1 Post
it depends on how much hp you have. the shorter gears are only make your car faster only if you have traction.
if you have a stock motor and are not boosting a lot >275hp then a b16 tranny will probably be faster.
but if you have like 400+hp and you have like no traction with 1-4th gear then a longer gear transmission will probably be better.
Re: B16 Transmission VS. GSR Transmission (riceball777)
can some one please tell me about how much power a stock b16a trans willl hold up to. or maybe a link. i've been searching and have found nothing. looking to get about 400-450whp
Re: B16 Transmission VS. GSR Transmission (4.8t)
b16 trans will hold as much as u want, but since your going to be slamming thru gears really fast, then as some may know, b16 does have weaker syncros than GSR, so expect it to go out quicker than a GSR would.
My 2 cent, i may have counted wrong lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">this thread is full of fail! the OP is asking which tranny will be FASTER and the answer to that is the one with the shorter gearing which would be the B16.</TD></TR></TABLE>
X2 he is right! Thread question is answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">it depends on how much hp you have. the shorter gears are only make your car faster only if you have traction.
but if you have like 400+hp and you have like no traction with 1-4th gear then a longer gear transmission will probably be better.</TD></TR></TABLE>
This makes no sense. If you cant get traction wouldnt you get items for better traction such as radials, slicks, traction bar, etc.
Re: B16 Transmission VS. GSR Transmission (Aladar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aladar »</TD></TR><TR><TD CLASS="quote">b16 does have weaker syncros than GSR, so expect it to go out quicker than a GSR would.
who told you this?
who told you this?
Re: (g0tgot)
i would say bottom line, b16 for the track and gsr for anything longer than that. and u cant forget about tire size, rpms, final drive (if u decide to mess with that too) etc, they also play a big factor in gearing and when it comes to getting traction, i would think more about the size slicks that your using. any high hp car would be worthless without getting traction
Re: (g0tgot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot »</TD></TR><TR><TD CLASS="quote">i would always run LS with a turbo set up....</TD></TR></TABLE>
I ran an LS for years boosted, its really ghey If you are putting down 500whp on the street I could see an LS's benefit but anything else no....
