Spool time and advice
I'm doing my first turbo build, and I'd like to hear some advice. Here's my define:
B18C1 block
ITR Crank
Eagle rods/Wiseco Pistons 9.6:1
B16 Head
AEBS IM
CTR/ITR Cams
PeakBoost Kit(A/C Ramhorn)
Garrett GT3071
Specs:
50 a/r 4inch inlet
71mm 56 trim wheel
flow: 46lbs/min
max WHP rating: 475whp
Turbine
T2 flanged .86 a/r
57mm 90 trim wheel
Copied directly from site.^^^
RC 750cc injectors
Walbro 255lph
Tuned on Hondata S300
I've been doing some more research, and I'm wondering what spool time would I be looking at? I'll be shooting for 350-375whp.
Also, I've looked through every discussion of GT30R vs GT35R. Should I have upgraded to the GT3076? Or will the GT3071 be a good turbo for this setup?
Modified by black_EM1 at 10:19 AM 1/5/2008
B18C1 block
ITR Crank
B16 Head
AEBS IM
CTR/ITR Cams
Garrett GT3071
Specs:
50 a/r 4inch inlet
71mm 56 trim wheel
flow: 46lbs/min
Turbine
T2 flanged .86 a/r
57mm 90 trim wheel
RC 750cc injectors
Walbro 255lph
