Spawne's supercharged B20, sponsored by DDTECH
Old Jul 6, 2012 | 08:43 PM
  #51
Spawne32's Avatar
Default Re: Spawne's supercharged B20, sponsored by DDTECH
Originally Posted by Gunmetal_B20_Hatch
any updates on the trans?
Buddy of mine is making a call tomorrow to get a quote on the work, i talked with a guy last friday about it and he just shook his head no at all the questions i asked him, and he never bothered to call me back. Also talked to Import Performance trans, or as you may know it IPT, and they told me flat out, and I quote "I wont even touch it.".
Old Jul 7, 2012 | 07:00 AM
  #52
2000GSRTypeR's Avatar
Originally Posted by Spawne32
4" hole saw, its a bit tricky, because the hole saw was for wood, havent found one made for metal so i just used that, gotta tilt the bit back a slight bit so it doesnt catch the lip of the VC and jam the drill up, but the guide hole has to be drilled right on the edge of the VC bottom. Once you get it going, it eats through that aluminum like butter.
Thank you sir! I actually used a 3 inch hole saw when I had to cut out the plastic on my CBR600RR for my frame sliders.
Old Jul 9, 2012 | 02:12 PM
  #53
Spawne32's Avatar
Been working on extending the wiring harness in various spots, relocating some wires, and swapping out connectors like my GM 2 bar map sensor. Also finished up with the valve cover. My buddy might airbrush DDTECH into the cover as well if he can get his airbrush working.
Old Jul 10, 2012 | 12:19 AM
  #54
turbohatch96y7's Avatar
Why not go with a vtec head? Don't know if it was already answered. Are you porting the crap out of the stock head?
I'm liking the color choice for the block.
Old Jul 10, 2012 | 07:37 AM
  #55
Spawne32's Avatar
The block is gunmetal, it was supposed to be like a metallic gray but the gunmetal changes color depending on the background lighting for some reason. Some days it will appear green, others it will appear brown, other times it will look gray.
I kept the non vtec head because I want the powerband to be consistent for a low revving motor, the vtec head port and cam design would push the power up beyond the 8000rpm range, and I dont want to run that on this particular motor with an auto trans. Im looking for peak power somewhere around 7000-7500rpm. The P8R head flows significantly better then the stock LS head because of the increase in valve size from 31 to 33mm. That is where most of the airflow is gained. The ports may not be as elongated as the vtec heads but I dont feel that it will hurt the flow at all.
Old Jul 27, 2012 | 12:44 PM
  #56
Spawne32's Avatar
Well this morning my engine fell out....
and before doing that, i decided to do all of this...
found out the coating on my supercharger is GONE, so i have to figure out what im going to do with that, probably just gonna strip it the rest of the way and leave it. Also finished mounting the alternator and testing the new pulley fitment and shimmed as necessary. Gonna finish wrapping the header and mounting the rest of the components to the new engine tonight.
Old Jul 31, 2012 | 07:32 PM
  #57
Spawne32's Avatar
decided to repaint the valve cover, teaser photo
Old Aug 1, 2012 | 12:48 AM
  #58
rich7777's Avatar
Looking good man That DDtech decal goes pretty sweet with it as well.
Old Aug 1, 2012 | 12:29 PM
  #59
th3pwn3r's Avatar
Agreed, that VC is looking pretty nice.
Old Aug 1, 2012 | 12:37 PM
  #60
Spawne32's Avatar
thanks, my buddy did all the airbrush work, he thought my original nighthawk black rattle can job looked like crap lol
Old Aug 2, 2012 | 07:38 AM
  #61
LS AzZkIkr's Avatar
Couldn't you use an automatic civic wither hatch or coupe and have this swap drop right in? That would make sense as long as long as the wiring/mounts are all the same. That is how it is with the manual cars motor mount wise.
Old Aug 2, 2012 | 08:00 AM
  #62
Spawne32's Avatar
The civic automatic is physically smaller then the integra transmission, including the internal parts and clutches. While it has the advantage of having an LSD option in one of the japanese m24a versions, it only uses 110mm drums, which makes it less durable then the integra trans. Wiring is completely different as well.
Old Aug 4, 2012 | 02:59 PM
  #63
Spawne32's Avatar
ported the supercharger
  #64
Spawne32's Avatar
heres the original dogshit casting
Old Aug 4, 2012 | 06:29 PM
  #65
MRGRIM's Avatar
R.I.P. Mark
still a huge amount of room for porting
did you match the port to the rotor timming ?
Old Aug 4, 2012 | 06:32 PM
  #66
Spawne32's Avatar
How do you mean match it for the rotor timing? We took an 1/8th of an inch off of each side of the port, cut a 60 degree bevel on the inside and hand filed it to the original shape. I know the timing is critical but working with such small increments i didnt think it would be something I had to worry about?
Old Aug 4, 2012 | 06:35 PM
  #67
MRGRIM's Avatar
R.I.P. Mark
you set the rotor at the inlet then you will see how much the outlet can be opened
Old Aug 4, 2012 | 06:37 PM
  #68
Spawne32's Avatar
ah ok ill have to double check that tomorrow, any idea if its possible to buy new M45 rotor packs by chance?
Old Aug 4, 2012 | 06:43 PM
  #69
MRGRIM's Avatar
R.I.P. Mark
no idea could just get it redone Veris had his done i belive with great results
have a read here as i explain the porting in 2 posts
https://honda-tech.com/forums/showth...1#post47534161
Old Aug 4, 2012 | 06:52 PM
  #70
Spawne32's Avatar
Yeh problem is i just cant afford the turn around time it takes to have it redone, so i was just going to strip the rest of the crap off and reassemble it. The bearings were flawless, nothing made noise, the oil was clear, and the coupler was great from the last time i rebuilt it 15,000 miles ago. How do you think it looks though on the outlet, we did everything down to a thousands of an inch on the mill. we even had to skim cut the back end of the charger so it sat perfectly level.
I havent done anything to the inlet but like the outlet, its got tons of casting flaws just coated with teflon.
Old Aug 4, 2012 | 07:03 PM
  #71
MRGRIM's Avatar
R.I.P. Mark
I did my porting and anothers freehand
after you have aligned the rotors and scribed the rotor alignmet you will find its not to hard
you will also notice to that the outlet has a very soft S shape to it its not a straight V this is to match the twist of the rotor edge
the reason for timming before porting is when the rotor in at 60deg inlet that side of the charger is now a sealed chamber full
of air so you want it to release it just after that at the opening/outlet allowing 1mm from the rotor blade to the outlet edge
doing this will cause the rotor to take its full amount of air and discharge it soon after
think of it like a combustion chamber
the total effect is more air moved with less delay raising your cfm and taking a lot of heat out of the rotor pack
Old Aug 4, 2012 | 07:08 PM
  #72
MRGRIM's Avatar
R.I.P. Mark
with the inlet its the oposite
with the rotor at 60deg you can see the gap to the next rotor of that side
being the floor of the charger housing
this can bee opened up and smoothed out to allow as much air as possible to fill it before it seals
if you loook at the pic above you can see that the floor has been soothed deep into it to allow air into the swept area
oh and re the teflon all three i have worked on have been stripped out and hand polished with a ultra fine metal polish
Old Aug 4, 2012 | 07:12 PM
  #73
Spawne32's Avatar
Doing yours freehand were you able to maintain that slight S shape? As far as we could tell there was nothing special about the shape of this outlet, other then how shitty it was. We did check for any sort of special shape to it and IMO there was nothing of significance in this particular cast. The blower case on the inside where the rotors spin is full of pits and holes from a porous air filled sand cast, the whole thing was completely uneven and had to be skim cut to even sit level on the mill and the outlet was so uneven from front to back we couldnt even get a measurement on it. I had been comparing port work from various "proffesionals" for the past month and ive seen some pretty bad hand ports that still made boost with no issues so i felt we did a damn fine job on the thing compared with what i started with.
Old Aug 4, 2012 | 07:14 PM
  #74
Spawne32's Avatar
Old Aug 4, 2012 | 07:35 PM
  #75
MRGRIM's Avatar
R.I.P. Mark
in regards to the porting I spent a lot of hours talking to pro's in the drag racing game
to learn the black arts of charger porting
even as far as to polish and not to polish the porting work
one engine builder showed me a cad flow movie on how the flow works on a root type charger and explained how to improve it and then show the effects of each modification
( I did spend four years in research before doing my jrsc build)
alot of the pits you describe would be damage from crap comming from the air filter
as far as the rotor striping Ive found if you carefully brush on paint striper you can get it of with out damaging the bearing seals at the gear end
when ive striped a few ive left the teflon alone between the rotor to gear case as it wont hurt it at all
