Spal 13" fan
Old 04-27-2009, 07:14 PM
  #176
wilham320's Avatar
Default Re: Spal 13" fan
18g is super tiny for a high amp fan motor.... the amperage was to much causing the hot wire. Wire it up with some decent wire with a relay and a 30amp fuse. Use the stock power wire going to the fan to activate the relay, then run a separate power from the juction box, and a nice ground.
Old 04-28-2009, 06:22 AM
  #177
90civichbsi's Avatar
i recently got the 13" spal fan and the difference was night and day.
my old setup: EBAY 12" and a custom fiberglass shroud I made.
this setup worked fine around town but temps would start to creep on the highway after the engine bay got heat soaked.
new setup: 13" spal and a custom sheet aluminuim shroud I made
No problems with keeping temps down at all and the fan doesnt need to stay on nearly as long as the old setup.
I would sell the old setup if anyone is interested. would work fine on an NA car as is. But would probably work very well with a spal 12" or something along those lines for a turbo car.
Old 04-28-2009, 06:28 AM
  #178
HELLO,GOOD MORNIN'
ahobbs's Avatar
Originally Posted by bigD
Question I have a fal fan ran off the stock wiring, it just started blowing a 25 amp fuse everytime it kicks on. I wanted to make sure the fan was still good so ran some 18g wire to the battery just to test it and let the fan run for 10 secs. when I went to remove the neg wire it was so hot it burnt my finger. Would that be from to small of wire or a problem with the fan, any other way to test the fan. I do plan on wiring it up the right way with the relay but wanted to make sure the fan was good first
something is wrong with the fan
wrong, fal fan is a stock replacement. It's a 9 amp fan. and can handle a 10amp fuse. just like stock.
Spal fan is a 18amp fan, that fan is high output and would require or (would perform the best) with a thicker gauge wire. i used 10gauge on mine and it's work great for months now not popped one fuse.
Old 04-28-2009, 06:33 AM
  #179
HELLO,GOOD MORNIN'
ahobbs's Avatar
^^^^^i've seen 90civichbsi set up and it's a goode efficient fan and he made an awesome shroud. I pushed him to buy this fan becuase it works well and he has reaped he benefits.
Old 04-28-2009, 08:56 AM
  #180
dpetro1's Avatar
i figured i would add that SPAL has a huge line-up of fans so if space permits there may be higher flowing fans available. i think we have gravitated to the 13" because its still fits the radiator and it fairly slim.
just trying to keep an open mind
Old 04-28-2009, 02:46 PM
  #181
legomytego's Avatar
is everybody buying the spal pullers or has anybody used the pushers i have my fan setup as a pusher right now and the car is over heating while going down the highway id like to keep it as a pusher but if its not going to do the job ill swap it just wanna order the right one thanks guys.
Old 04-28-2009, 03:42 PM
  #182
as far as puller fans this is the 13" most people buy
http://www.the-fan-man.com/shop/size....html?cPath=33
Old 04-28-2009, 03:49 PM
  #183
bigD's Avatar
when building a shroud is there a distance that that works best between the shroud and the radiator. It looks like most are 1/2 inch to a inch away and sealed all the way around correct?
Old 04-28-2009, 06:22 PM
  #184
dpetro1's Avatar
the pusher equivalent to the fan we use is spal part# 30102045 and is rated at 1642cfm http://www.spalusa.com/store/main.as...&item=30102045
Old 04-28-2009, 07:35 PM
  #185
wilham320's Avatar
Misread the FAL Part.... thought he was talking about the SPAL.
Old 04-28-2009, 07:44 PM
  #186
legomytego's Avatar
do you think it will work well enough as a pusher ? i just dont wanna order it then the car still overheat cause its not as efficient as the puller would be.
Old 04-29-2009, 05:31 AM
  #187
dpetro1's Avatar
im sure it would be a major upgrade but dont think that just putting on a better fan is the be all end all. you still need to make sure your radiator is getting some airflow at speed. my experience was that even the puller fan was unable to keep up in 90* weather on the highway after about 1 hour. hybridcivicls-t's setup is pretty much the ideal way to ensure the car will not overheat (fan w/ shroud, vented hood, cut bumper, the works)
Old 04-29-2009, 08:12 AM
  #188
official honda whore
EARLdaSQUIRREL's Avatar
just ordered the fan from the-fan-man, looking forward to cooler ect's
Old 04-29-2009, 02:35 PM
  #189
legomytego's Avatar
same here i hope it takes care of my problem for now i went all last year with some cheap *** 12 inch fan autox my car and everything now it wants to over heat. going back to read the thread over loads of info in here.
Old 04-29-2009, 04:33 PM
  #190
wade's Avatar
fan kicks ***. Is there anyway that when it is ON, I dont have such a drastic battery/amperage draw from the car?
any ways to cure it? higher output alternator?
Old 04-29-2009, 05:45 PM
  #191
96 GSR-T's Avatar
Are you using a relay with large wire to power your fan?
I saw some pretty nasty ECT's (220ish) last year in the summer so I am going to have to do something about it..... this 13" spal and a shroud sounds like a winner.
Old 04-29-2009, 07:15 PM
  #192
tony1's Avatar
Actually, people gravitated to the 13" Spal because I put one on my car and shared the results.
Old 04-29-2009, 08:13 PM
  #193
Boosted_Coupe's Avatar
Lot's of great information, thank's guy's!
Old 04-29-2009, 08:49 PM
  #194
HELLO,GOOD MORNIN'
ahobbs's Avatar
that's why i got it. I fussed and complained about paying for it but it was the only resolution for my car.
Old 04-29-2009, 11:46 PM
  #195
HiProfile's Avatar
For a puller setup, at least 1" is ideal, but 1/2" is still far better than no shroud. Sealing it will help too, but you don't need to go crazy. The area and pressure drop of a thick rad means an unsealed shroud won't affect temps enough to notice.
grabbing a turbo blanket or just pulling the bumper if needed. the car has stayed rock solid at 186* any other time since i installed the fan back in november
Blanket, wrap, or shroud. Shrouds don't affect looks, holes make it looked rigged to EVERYONE, wraps & blankets show your **** is so awsome you have to sheild it from ninja spies. However 203F isn't super hot. At 1bar (0psig) water boils at ~212F, but MUCh higher a normal car coolant system due to pressure & antifreeze. Speaking of glycol, using less increases cooling capcaity.
Old 04-30-2009, 03:17 AM
  #196
BB6-213's Avatar
subscribed
Old 04-30-2009, 04:25 AM
  #197
Turbo-charged's Avatar
getting ready to use this fan in 4 different cars including my own. im done with dealing with shitty fan/cooling set ups lol
Old 04-30-2009, 04:45 AM
  #198
dpetro1's Avatar
lol, good point. props to hybridcivicls-t for taking the time to post up datalogs and take some sweet one handed pics of his laptop while in boost too. that data helped alot.
damn ninjas, ill never let them see my gt30r turbine, im wrapping that **** up immediately. i didnt really mind 203F but i know it would have continued to creep the longer i drove.
Old 04-30-2009, 07:31 AM
  #199
HELLO,GOOD MORNIN'
ahobbs's Avatar
i didnt really mind 203F but i know it would have continued to creep the longer i drove.[/quote]
i do! shouldn't go above 195 IMO
Old 04-30-2009, 07:54 AM
  #200
So the correct part number for this fan is 30102044
Quick Reply: Spal 13" fan
