smc vs S-afc ??
Old Nov 18, 2003 | 08:22 AM
birz's Avatar
Default smc+ vs S-afc ??
should I swap my SMC+ for a S-afc?? whats the pros and cons of each?
im running a T25 on a B18B@8psi
I'm not planning to go any higher in boost, 8psi is just perfect for me and my wallet. I do have a acouple of problem with my setup, like in low throtle I have hesitation and my idle runs erraticly, sometimes it even stalls. Full throttle there is no problem of hesitation whatsoever. I never lean in boost. What is the cause, my fuel management or my ignition? I might plan to buy an MSD btm6, but if it's only the FMU, let me know. Thanks
Modified by birz at 5:41 PM 11/18/2003
Old Nov 18, 2003 | 09:42 AM
Slammd Sol's Avatar
Default Re: smc+ vs S-afc ?? (birz)
I have had both. Lemme Tell ya.. AFC > SMC Id take my AFC over the SMC anyday. My turbo setup ran 10x better on the AFC. Its also Much easier to change/view settings, plus the AFC can log.. Only pro the SMC has is price, but you get what ya pay for..
Old Nov 22, 2003 | 02:04 PM
birz's Avatar
any other comments???
and should I upgrade to the SMC 500?? its 30$
Old Nov 22, 2003 | 02:10 PM
baphomet's Avatar
Default Re: (birz)
you should maybe tune it a bit more, and keep the smc+.
Old Nov 22, 2003 | 02:17 PM
RTE117's Avatar
Default Re: (slashDEVslashNULL)
i'm not sure what the best version of the SMC is, but from what i've heard.. it's less of a hassle than the AFC.. and since you already have the SMC why get rid of it?
Old Nov 22, 2003 | 02:21 PM
birz's Avatar
Default Re: (IDriveAHonda)
cause I have an erratic idle and hesitation on part throtle (the car bugs when I'm not WOT)
I dont know if I can tune it properly, anyway thie spring I'm going to put Arias pistons in, and an MSD BTM. I will have to tune from scratch again.
Is it possible to get rid of the hesitation problem with only the hack???
Old Nov 22, 2003 | 04:10 PM
integrx's Avatar
New User
wait you are running the FMU too?
Old Nov 22, 2003 | 04:32 PM
birz's Avatar
Default Re: smc+ vs S-afc ?? (integrx)
no,, no fmu
-b18b1 (stock internals for now) burn oil like hell, thats why I get it rebuild this spring with forged pistons
-450cc talon injector
-turbo T25 (8psi)
- GSR tranny
-SMC+
Old Nov 23, 2003 | 06:12 PM
Deltax75's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birz &raquo;</TD></TR><TR><TD CLASS="quote">no,, no fmu
-turbo T25 (8psi)
- GSR tranny
-SMC+
I would suspect your injectors for your idle problem. I originally used some C&B'd dsm 450's and had a very rough idle. Then i tried saturated 550's from viren (b18bturbo), run -45% at idle and have never had a problem. I think the key was switching to saturated over peak&hold. -Mike
FallenEGsi
Feb 5, 2004 02:18 PM
iwouldHITit
Jan 18, 2003 12:26 AM
JeremyL
Dec 13, 2002 12:36 AM
legendboy
Jul 11, 2002 07:27 AM
98civicEX
Jul 6, 2002 09:31 AM
