intercooler piping, hard??
Old Nov 23, 2003 | 04:28 AM
ek_will's Avatar
Default intercooler piping, hard??
i've always seen people trying to sell pipes or sites selling pipes on sites "made for intercoolers" but you still have to cut n fab yourself. But arent they still just pipes couldnt you just go to home depot buy yourself some mandrel bent piping and DIY? is it that hard? or is there something i dont know about.
Old Nov 23, 2003 | 04:33 AM
rjardy's Avatar
Default Re: intercooler piping, hard?? (dash0n)
jcwhitney.com
I just bought mandrel bent pipe, cut, fit, then weld, they came out clean.
Rob
Old Nov 23, 2003 | 08:26 AM
PHiZ's Avatar
Default Re: intercooler piping, hard?? (rjardy)
http://www.cse.uconn.edu/~yele....html
This guy shows the shapes of the pipes needed.
-PHiZ
Old Nov 23, 2003 | 08:34 AM
patdemps's Avatar
Default Re: intercooler piping, hard?? (PHiZ)
JC whitney
Old Nov 23, 2003 | 08:51 AM
danl's Avatar
Banned
Default Re: intercooler piping, hard?? (patdemps)
DIY, twice the quality at half the price. Buy 304 series mandrel bent stainless steel bends from JC whitney or mcmaster carr. Jegs sells the cheaper 409 series and their 2.5" mandrel is IMO not a true mandrel. However, their pipes are very cheap but not as polished as the master pieces. You get what you pay for. Then buy some 3 or 4 ply couplers with t-bolt clamps. Or do what I did and put tacks on the pipes for the couplers to slip over and then clamp it down. Its held 25 psi so far.
Old Nov 23, 2003 | 08:54 AM
tegasaurus's Avatar
Default Re: intercooler piping, hard?? (danl)
Do you have the link you got your pipes from on mcmastercarr? I have the one fo jcwhiteny but i thin ktheir piping is too small of a gauge, i'd like as little weight for piping as possible.
-Ryan
Old Nov 23, 2003 | 09:01 AM
ek_will's Avatar
looks good but do i need all that just for i/c piping ive got the rest already from greddy.
Old Nov 23, 2003 | 09:43 AM
danl's Avatar
Banned
Default Re: intercooler piping, hard?? (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">Do you have the link you got your pipes from on mcmastercarr? I have the one fo jcwhiteny but i thin ktheir piping is too small of a gauge, i'd like as little weight for piping as possible.
-Ryan</TD></TR></TABLE>
I got mine from JEGS. Its a 2.5" mandrel bent U pipe and I only needed one piece. It actually necks down to 2.25" in the middle, which I was not pleased about. However in the end it actually did not affect anything. I bought a 2.5" straight piece from mcmaster carr, and its VERY thick. Allmost twice as thick as teh JEGS piece. If you want good looks, you allmost have to go with the mcmaster pieces, they are awsome, but heavy. I spend a fair amount of time in front of a wire wheel making those JEGS pipes look decent. They just take a little prep time. Stainless steel is the way to go though, its just pimp.
Here is the link to the JEGS pieces:
http://www.jegs.com/cgi-bin/nc...r=361
Old Nov 23, 2003 | 01:08 PM
TurboR1391's Avatar
Custom is the way to go if you have patience for down time.
Old Nov 23, 2003 | 01:57 PM
teal EJ1's Avatar
Default Re: intercooler piping, hard?? (TurboR1391)
i agree DIY, measure twice cut once
Old Nov 23, 2003 | 02:28 PM
int3gra's Avatar
Default Re: intercooler piping, hard?? (Peter North)
someone stated a while back that its cheaper to buy two cold air intake setups from ebay and just use those, they are already blinging
Old Nov 23, 2003 | 06:01 PM
ek_will's Avatar
Default Re: intercooler piping, hard?? (int3gra)
would be good if i needed intake piping but all i need is from turbo to IC and IC to intake pipe not the intake piping itself so looks like ill just custom it and hopefully there wont be to many complicated bends. i hear pple use some kind of diseal type silicon couplers(sp?) to tie the pipes together any idea where i could find some?
Old Nov 23, 2003 | 06:08 PM
SOFLSOL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra &raquo;</TD></TR><TR><TD CLASS="quote">someone stated a while back that its cheaper to buy two cold air intake setups from ebay and just use those, they are already blinging </TD></TR></TABLE>
I'm actually using this for my upper charge pipe and had my bov welded to it. Looks pretty good. And the rest are mandrel bends from JCWhitney.
Old Nov 23, 2003 | 06:19 PM
playAho's Avatar
phiz
that is like turbo kits for dummies it helped thanks.
thegatekeeper14
Welding / Fabrication
18
Apr 19, 2011 07:50 PM
forcedaccord95
May 13, 2005 08:19 PM
civtic
Jan 10, 2004 06:00 PM
hatchy
Aug 15, 2003 05:26 AM
therealciviczc
Jan 17, 2002 11:24 AM
