fmu vs safc?
Old Dec 7, 2002 | 01:09 PM
JeremyL's Avatar
Default fmu vs safc?
which is the better way of tuning a turbo b18b without standalone mgmt?
Old Dec 7, 2002 | 04:59 PM
Adriano's Avatar
Default Re: fmu vs safc? (JeremyL)
safc with some dsm injectors
Old Dec 7, 2002 | 05:18 PM
coyote's Avatar
Default Re: fmu vs safc? (brryder)
how much can you boost on that setup ? and what about timeing ??
Old Dec 7, 2002 | 05:24 PM
ion_four's Avatar
Default Re: fmu vs safc? (coyote)
you can boost 12-14psi, depending on how rich you want to run, because the more signal you trim out of the MAP the more boost you can run, but also the leaner you run. there are alot of threads on this if you do a search.
Old Dec 7, 2002 | 05:28 PM
coyote's Avatar
Default Re: fmu vs safc? (ion_four)
i did do a search but no one seem to beable to tell be about weather i will have to up grade to something that will retard my timeing under boost . or if i can just do it my self and be fine.
Old Dec 7, 2002 | 06:22 PM
jinxproof99's Avatar
New User
get both(safc & fmu)
Old Dec 8, 2002 | 06:03 AM
JeremyL's Avatar
Default Re: fmu vs safc? (jinxproof99)
ok i know pretty much what an FMU does but what does a SAFC really do? i would think it would be simpler to tune than a VAFC since im not gonna be dealing with rev limits and vtec engagement
Old Dec 11, 2002 | 10:15 PM
youngkow's Avatar
Could you really use the safc with the fmu? Would that be much safer?
Old Dec 12, 2002 | 12:01 PM
TeStUdO's Avatar
Default Re: fmu vs safc? (youngkow)
save money and buy the smc, its so much easier to use on the fly, all you have to do is hit the program button. with all the money you save you can buy a wideband o2 and tune it better on the street. also on the timing issue either get an msd btm or just retard the ditributor like 3 gegrees. i would go half a degree every pound of boost.
Old Dec 12, 2002 | 01:52 PM
pelotudo's Avatar
Default Re: fmu vs safc? (00si5)
SMC w/ DSM 450cc injectors
jB
Old Dec 12, 2002 | 01:54 PM
coyote's Avatar
Default Re: fmu vs safc? (PeloTudo)
ok what is the SMC and how much is the wideband o2 ?
Old Dec 12, 2002 | 01:58 PM
pelotudo's Avatar
https://honda-tech.com/zerothread?id=310021
https://honda-tech.com/zerothread?id=304395
https://honda-tech.com/zerothread?id=298896
https://honda-tech.com/zerothread?id=349129
jB
Old Dec 12, 2002 | 05:06 PM
TeStUdO's Avatar
he just hooked you up if you need some help with hooking it up or tuning just ask me ill help you, or you can always do a search
Old Dec 12, 2002 | 05:42 PM
coyote's Avatar
thanks for the hook up man i am read all the stuff now ..
Old Dec 12, 2002 | 06:23 PM
Mr.DC2TurBo's Avatar
I hear ppl saying afc hack works but is there anyone willing to tell me their Hi/LO readings for 1-7K rpm??? I have been asking HELP about my afc setting with 440cc injectors with intank pump and no one seems to know or help? Ppl say it works but have they really tried it for themselves or heard others saying that it really works? I am running the afc and I'm ******* throwing codes and my exhaust fumes smell really rich.. I have it my settings HI/LO 1-4k at -50%, -50%, -48%, -45%. and 5-7K from -40 to -35%. trottle HI/LO = 72/71. What the hella is wrong with my setup???? Can anyone HELP?????
Old Dec 12, 2002 | 07:01 PM
pelotudo's Avatar
Yes. The SMC is one of the best pieces I have used on my turbo setup. 1/2 the cost of the AFC, with the same function and ease of use. You don't get the pretty bright blue screen, but I don't care. Tuning is a piece of cake, and installation is easy enough for my 9 year old nephew to do. Zip is the man, and his piece is truly amazing. You can get one at http://www.diabloautosports.com for like $111 I think, + s/h. I got mine for $89 when it was first introduced, but I would easily pay $125 for what it does and how professionally it was built. to Zip for this alternative to the SAFC hack.
Dr. I wish I could help you. W/ the SMC I had my fuel settings at 42%, 37%, 34%, 34% across the board (idle-1500; 1500-4k, 4k-6k, 6k+)...the SMC took care of the rest. Good luck getting everything running okay..once you do, you'll be amazed at the power increase over being untuned.
jB
[EDIT]
Here's a link directly to it:
http://www.diabloautosports.com/prod...52c485bddc3d56
They're up to $114.95 now, well worth it still IMHO
[Modified by PeloTudo, 11:03 PM 12/12/2002]
Old Dec 12, 2002 | 08:10 PM
JeremyL's Avatar
well i wont know about the differences cuz i aint gonna be driving untuned
i found a guy who put a turbo'd H22 into a civic and is running 10lbs daily driven and very frequently track driven and says hes been running it for a long time with just an AFC and a missng link and has had no problems
and i like the pretty blue screen lol
Old Dec 13, 2002 | 12:36 AM
SIK IN DA HED's Avatar
New User
stick to the fmu... and tune it out with the safc. try the hack... it works for some... not for others. so far the smc has had good reviews... maybe you can try that out.
kholmes
May 10, 2004 07:08 PM
FallenEGsi
Feb 5, 2004 02:18 PM
untitled
Mar 19, 2003 06:27 AM
Sohc Driver
Mar 15, 2003 11:42 AM
vteckiller
Jul 15, 2002 12:53 PM
