Block Gaurd or Sleeve?
I have a 96' gsr that i am hopefully going to turbo, i am rebuilding it with all low comp. pistons and forged rods, i want to run about 13 or 14 psi but am not sure if the stock sleeve will hold up or not, cuz that would be some money saved?
even 1lb of boost requires sleeving
not..... search for what you want to know... probably under "stock block". You have a lot of reading and research to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav95civic »</TD></TR><TR><TD CLASS="quote">even 1lb of boost requires sleeving</TD></TR></TABLE>
uuuh ok...
uuuh ok...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hotori Hanso »</TD></TR><TR><TD CLASS="quote">
uuuh ok...</TD></TR></TABLE>
its sarcasm buddy
its sarcasm buddy
dont measure your goals in terms of PSI because its an irrelevant measurement. Also, you probably dont need aftermarket sleeves or want a block guard. There are several cars in the upper 400s safely on stock sleeves and i know there are more beyond that even....
downside to having it without machining is distorting your cylinder walls, thus causing irregular wear. also, blockage of coolant passageways causing overheating.
14 psi of boost. stock sleeves with forged bottom end and a great tune would do wonders
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BmfoHPWW »</TD></TR><TR><TD CLASS="quote">Thanks alot i think that the stock sleeves, with the forged bottom end seems to be the way to go!</TD></TR></TABLE>
yep K.I.S.S. KEEP IT SIMPLE STUPID !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 »</TD></TR><TR><TD CLASS="quote">stock sleeves, 81.5mm bored, 10:1 compression pistons ftw</TD></TR></TABLE>hey you just listed my motor from last year buddy...i ran it at 22lbs of boost from an sc61 then i sold it after the season...still running strong for the new owner
LilCivic04
Feb 1, 2005 06:17 PM
imthedude
Oct 16, 2003 09:44 AM
