The Shodan & Project GHOST!!
Old Apr 20, 2019 | 06:19 AM
  #201
TheShodan's Avatar
Moderator
Default Re: The Shodan & Project GHOST!!
Originally Posted by Dee
I did have one that lasted for 9 years and transferred between 4 cars thanks to periodic cleaning and oiling but the pic below shows what almost killed my '08 STi Hatch. This is the same multi-layer filter that you have. Symptoms of failure were all over the map so I decided to just check everything in the car after the second occurrence. First time I thought I had a bad MAF so I gave it proper cleaning and let it air dry for 2 hours. Second occurrence seemed like a bad fuel pump, that is a notorious GRB STi failure, after cleaning the MAF again. Eventually I pulled the air box apart and found the crumbling filter.I cannot find the pics of my friend's RX-7 filter that died but it was a brand new replacement filter, purchased from an authorized HKS dealer, that fell apart 2 months after purchase. He was really OCD about filters, oil changes and detailing the car. I have actually seen quite a few of the HKS filters fail over here. I thought the other failures were flukes until it happened to me.
Caveat: I have no idea how long this filter had been on this pampered 32k km (20k miles) car when I purchased but the previous owner drove the car less than 1200km in a 2 year period. I know this because mileage (km in my case) gets documented between inspections.
Him. One to grow on more, I see. thank you. I'll lb. l now know tip keep an eye out for it.
Old Apr 20, 2019 | 06:21 AM
  #202
TheShodan's Avatar
Moderator
Now to change the seats. the stock ones fell like riding on a couch.
Old May 24, 2022 | 08:12 AM
  #203
TheShodan's Avatar
Moderator
Yes. I'm actually bumping a thread that is almost 10 years old. But that's how long it took to finally get Project Ghost finally out onto the streets. MY GOD.
IF you guys even care about this anymore, since it's been so long, below is link to a small video, and the parts description is ALMOST the same as on page one, but I'm just glad it's still going.
This was one of the LAST of Spoolin' Performance's manifolds/ hot-parts kits that he made before retiring.
Break-In tune for the VelociRaptor is a scant 8psi with about a 4500rpm redline set to cut boost. No Meth-water has been introduced yet.
The car REALLY needs an alignment, and I think Ghost is in a little bit of a pickle because of the custom wheel choice he made years ago was of an offset that isn't ideal (+35)... But after the break-in mileage we're off to do a full tune at Japanese Automotive.
And yes. Those are genuine Honda CTR EK9 headlight assemblies. ;-),
And Yes.. That is an original HKS Filter. No eBay version at all.
I will say that these cams still sound awesome after all these years. Please enjoy. It's one of the last projects I think I'll be doing for a while.
The Resurrection of Project Ghost
Old May 24, 2022 | 01:08 PM
  #204
ls joker's Avatar
Loved
Congrats. You guys were working on that forever. Thought he switched to the ultra street manifold for whatever reason. Obviously the car hasnt ran long enough to check for wear from the T1s. But how bout your rockers on the integra. Just curious.
Old May 25, 2022 | 06:32 AM
  #205
TheShodan's Avatar
Moderator
No. Glad he didn't, actually, as that just would have been more work, and for the power to be made, after using a couple of those sets of cams over the years, that manifold isn't much of an upgrade. I see more of a benefit to the NA crowd, IMHO.
Rockers have been fine on mine and a few others for years, and I recently checked mine a coupleof years ago. I'm actually not that concerned about the wear as long as the valve lash was correct.
Old May 25, 2022 | 07:30 AM
  #206
scottcraft's Avatar
10 Year Member
Loved
Community Favorite
That idle sounds so nasty!
Old May 26, 2022 | 03:12 AM
  #207
ls joker's Avatar
Loved
Good to hear.
car just needs a drop and some tint.
Old May 26, 2022 | 07:39 AM
  #208
Dee's Avatar
Dee
**EDIT**
Oops. I see I already made a comment about the filter. That engine sounds sweet.
Old May 26, 2022 | 03:52 PM
  #209
highschooler's Avatar
Very good to see progress on the project! It sounds good.
Old May 31, 2022 | 05:50 AM
  #210
TheShodan's Avatar
Moderator
She has to do well. this is one of my last projects forever. Getting older, and want to pursue some other interests. After 20 years even on this forum, you want to end on a High note
1. Still needs alignment badly (more likely the toe in is too severe)
2. Shift linkage bushing and bolt to the shifter need replacement
3. Continue another 500miles of break-in time
4. ensure that the brake pads can hold the power
5. replace the windscreen (if something new still exists for that generation civic)
6.get the right water /meth injection
After that, we can do final tune, get the Recaro seats and be done. I think we can reach the 500whp mark reasonably. But the turbo's oil pressure and oil cooler work Great!
More to come.
Old May 31, 2022 | 05:51 AM
  #211
TheShodan's Avatar
Moderator
Good to hear.
I wish it could be dropped more, but the owner order the wheels in a +35 offset, using a Falken Azenis 215/45/16 combination. I didn't know that he got a +35 offset, otherwise we could drop it more. I'll see if he's willing to put the other 16" with the proper offset back on for the rest of break-in and tune.
Old May 31, 2022 | 01:55 PM
  #212
Stopsign32v's Avatar
Loved
"proper offset"?
My car sits quite a bit lower with +35 offset and I have untouched fenders. No reason you can't lower that car more.
Old May 31, 2022 | 06:13 PM
  #213
Chrisfrom1986's Avatar
Originally Posted by Stopsign32v
"proper offset"?
So you're also using 215/45/16 Azenis?
Old Jun 1, 2022 | 03:58 AM
  #214
Luke_V-tec's Avatar
loving this revival of a build thread.
can I ask you if you can provide some close ups of the coolant lines on the turbo? Where it’s returned and where you pick the coolant up from? I’d love a close up just to see how you’ve routed them. Thanks in advance
Old Jun 1, 2022 | 08:21 AM
  #215
TheShodan's Avatar
Moderator
"proper offset"?
Well, the fenders aren't rolled, and will probably need to be, as he scrapes on a few bumps... (we are in an area of America that doesn't do the best to keep its roads smooth. ;-) )
But also, it's time to change suspension. So, TEIN Mono Sports w/ EDFC are on order.
I can see what I have. I may need to take more. But we used the B&R water fitting kit, and had an adapter drain plug for the Skunk2 Radiator that he's using.
Old Jul 14, 2022 | 06:13 PM
  #216
If the car still has the Moroso 5 quart oil pan, I’m wondering if it affects ground clearance while driving on the street, or does it just have a kick-out?
Is it the same as this one, or an older/different type?:
https://www.moroso.com/acura-honda-b-series20901/
Old Sep 26, 2022 | 01:47 PM
  #217
TheShodan's Avatar
Moderator
I believe that although similar, Project Ghost has the Street Moroso.But no, there are no ground clearance issues.
Street Moroso pan
In the meantime. He's getting rid of the Japanese swift spring kit and going with This classic instead using the EDFC Activ. These were ordered in July, and just came in as of Sept 10.. . We are definitely going back to the days of old, when I was used to waiting for parts from Japan, back in 2006.
The Azenis tires will still be used, but the wheels will be removed and possibly sold. There's another set of wheels he has with the correct offset, it's just not worth trying to keep, and possibly damage.
Old Sep 26, 2022 | 01:54 PM
  #218
TheShodan's Avatar
Moderator
"proper offset"?
I forgot to answer this. It's the 215 width tyres with a 35+ that are the main reason why this can't be dropped more. If it were a 45+ offset, he'd be fine.
Old Sep 26, 2022 | 02:46 PM
  #219
ls joker's Avatar
Loved
Kinda confused on that tein setup. Hes using another tein kit. Just not with the electronic active dampening stuff?
Old Sep 27, 2022 | 09:42 AM
  #220
TheShodan's Avatar
Moderator
No, He had Swift Springs/shock combination from way back in the day. He's now going with the TEIN Mono Sport kit with the EDFC Activ controller.
My apologies if I wasn't clear before..
Old Sep 29, 2022 | 05:23 PM
  #221
0c00l's Avatar
Nice work Mr.S :D
Old Sep 30, 2022 | 01:49 AM
  #222
ls joker's Avatar
Loved
Haha, i just went back and reread it. Yea the swift spring are retro lol. I remember i wanted the tein street kit for my Da9 way back in the day.
His car needs a drop bad.
Old Sep 30, 2022 | 06:50 AM
  #223
TheShodan's Avatar
Moderator
Haha, i just went back and reread it. Yea the swift spring are retro lol. I remember i want the tein street kit for my Da9 way back in the day.
I know. The worst part is that it rides as though its Slammed to the ground. I also think that the AZENIS tyres are really old technology and always rode ROUGH..
Old Sep 30, 2022 | 05:42 PM
  #224
ls joker's Avatar
Loved
Rough lIke they dont really feel like a true 200 or whatever treadwear? I dont believe they were actually r-comps, just an extreme summer tire or whatever marketing term was popular back then.
Old Oct 12, 2022 | 11:01 AM
  #225
TheShodan's Avatar
Moderator
Absolutely. The sidewalls are stiff to say the least. Back then we were younger and could handle the jarring and rattling. Not so much , anymore.
luv2boost
May 25, 2022 07:57 PM
discopotato03
Apr 12, 2006 05:27 AM
Bailhatch
Dec 10, 2003 09:20 AM
