The Shodan & Project GHOST!!
Hontoo?? Another Project? Hopefully this will make for an interesting project as this will be the last B-series Project for a while. Onto an F2K-series and K-series turbo project next year. Please wish me luck as I document. Edit - 2018. Things change & stay the same....
Teaser. Stay tuned.... |
Re: The Shodan & Project GHOST!!
Nice! Casper white!!
GTX unit, Mac? What's the projected goal?
That turbo looks FU*KING SICK ! I demand more pictures and info !!! NOW !!! ;)
Reaper or GTX?
I cannot wait until I am ready to purchase a Reaper from you! I just hope it's within my budget with what I am doing over the winter...
Originally Posted by LS AzZkIkr
(Post 46157014)
Hello and welcome to my build thread. I have entrusted Mac to take this thread and make it something wonderful like he has done so many times before. As time goes on you will see some very interesting items that I know you will have questions for. I am prepared to answer them as best as possible. I'm sure that Mac will definitely have many technical specs as he always does. Its nice to have someone that I can literally call at anytime of the day and get info and support about my build.
I'm really happy with this build as of the last few weeks. I have had my run-ins with some unlucky gremlins along the way and have found a new "Network" of trusted people. We shall call these lucky people "My Man". "My Man" has knowledge and support like no others. Professional people doing professional jobs all the time and on time. This to me is worth more then the build and the end result.
Originally Posted by BigMike0147
(Post 46152899)
Originally Posted by Silva Bullit DC4
(Post 46153084)
Originally Posted by rich7777
(Post 46153274)
Originally Posted by Gunmetal_B20_Hatch
(Post 46153548)
Reaper or GTX?
Originally Posted by TheShodan
(Post 46154192)
This is a GT3584R "Reaper" made from a GT3582R in a .63A/R T31 4 bolt that used an older styled Anti-surge compressor cover. The unit was originally used, and was refurbished to accept the newer wheel. Had I not been able to clip the turbine wheel, it would have been a lost cause.
The GTX is an 11-single bladed setup, while the GT3584R Reaper is a differentiating 6 spoke splitter-bladed design. I'll give a bit more detail soon, k? Thanks for the comments. Please ask questions. If you don't ask, then who will? |
Just a tiny little small update. I picked up the motor yesterday. OMG it's sex on an engine stand. I mocked up the manifold, turbo and downpipe. We snapped a few picks and did a small video. Your going to have to wait for Mac to upload them as he used his cameras.
isnt the gt series the gt series because of the exhaust wheel? is that just a really old gt35 before they had their own exhaust wheel?
what does clipping the exhaust wheel accomplish? i know dsm guys used to do it back in the day, havent heard of people doing it recently |
Originally Posted by Casey
(Post 46157830)
what does clipping the exhaust wheel accomplish? i know dsm guys used to do it back in the day, havent heard of people doing it recently Mac is the man! You went to the right guy to get shit done. Just be careful of that crazy english bastard over there. lol |
So it is a ball bearing unit then?
its got coolant ports on the chra so its a bb unit from what i can tell.
i thought thats what clipping did, just havent looked into it much at all |
Originally Posted by tepid1
(Post 46158014)
Bigger flow little package.
The initial "Video" of the engine when he picked up the engine is pictured below. under the video are the specifications of the engine. Please note that not all parts me neither recommended by me or J3573r. This was from the previous "builder" before going to Autowerks Motorsport. J3573r decided to just keep what he had an not try to resell and change out.
This project was put on the back-burner for a while because of the fact that the engine needed to be inspected and cleared by Autowerks chief mechanic Andy N. He found several issues that would have proven catastrophic if not at least costly had he not performed this inspection. Once this check was performed, he completed assembly. Specifications of the engine. Please note, some of these parts are controversial and not of our original design B18C1 - Engine Block *PROBE PISTONS -81.5mm 10.47:1 Stock sleeves *PROBE RODS- similar to Eagles *ACL Bearings using a micrometer to confirm measurements *ARP Head studs *ARP mains *ARP Rod bolts for PROBE rod replacement *ARP Crank pulley, clutch & Flywheel Bolts *OEM GS-R Crank 87.2mm *OEM P72 Head Gasket *MOROSO 5QT Oil Pan *Gates High Tension Timing Belt *OEM GS-R 22T Water Pump *OEM GS-R Oil Pump *B&R Fittings Catch can and water line kit *Clutchmasters FX400 - *EXEDY 12lbs Flywheel Cylinder Head *GSC T1 Camshafts 1-25-2013 *TODA RACING CAM GEARS *SUPERTECH FULL VALVETRAIN (DR Series) *SUPERTECH Flat-top NITRITE-TREATED VALVES *SUPERTECH VALVEGUIDES *"3-Angle" Valvejob *Skunk2 Alpha 70mm TB *OmniPower 4bar Map Sensor *OEM TPS sensor *SKUNK2 PRO1 Intake Manifold *BDL Fuel Rail *BDL Cam Seal *BDL Fuel Pressure Regulator Forced Induction Components *Spoolin' Performance Quick4 AC Exhaust manifold *Spoolin' Performance 3" 4 Bolt Downpipe *TiAL 38mm MV-S Wastegate 11.75psi wastegate spring *TURBONETICS "Godzilla" Blow off Valve *Go-Autowerks 2.5" Intercooler Piping - *Garrett Single Back Door 20 x 10.5 x 3 Intercooler Anodized Turbocharger *STC TR3030R "VelociRaptor" Turbocharger *T31 2.5" 4 bolt turbine housing .63A/R turbine housing |
(Post 46158139)
(Post 46158187)
What english bastard lol ? me ?
Interesting manifold, Is that angle of the center section ok? i know there is a certain degree before its an issue just nto sure how much.
Originally Posted by Turbo-LS
(Post 46158541)
Interesting manifold, does it clear a/c compressor? Is that angle of the center section ok? i know there is a certain degree before its an issue just nto sure how much.
i re-read the build list and saw that LOL
(Post 46158605)
(Post 46158388)
No, STC's Peter MacFarlene.
Did it cost a lot to get that intercooler anodized if you don't mind me asking ? |
(Post 46159078)
Silly me, i thought he might have read something i posted up. I didnt quite get the "other there bit"... So now i know how you know what real "crisps" are :P . He,he,he...
Did it cost a lot to get that intercooler anodized if you don't mind me asking ? Here's an example of one of the Garrett ones done http://img.photobucket.com/albums/v2...1/IMAG0186.jpg |
Thanks for the info & picture. I'll bear that in mind if i ever want it done. How well do those Mishimoto intercooler work compared to a Garrett equivalent ? I'm going to need a better intercooler for the forged block that i'm building i think. I'll pm you sometime in the future about that though if you don't mind.
(Post 46159372)
