setup question?
Old Jan 27, 2008 | 01:47 PM
watanabefan's Avatar
Default setup question?
Hey i was wondering if anyone has ran this setup and how well it worked..
ls/vtec turbo with jdm type r pistons and how much boost would i be able to run....
thanks
Old Jan 27, 2008 | 06:25 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: setup question? (watanabefan)
I never like to say never, but that is really an NA setup...
Old Jan 27, 2008 | 08:08 PM
blinx9900's Avatar
which type r pistons? itr or ctr?
if its itr maybe a little boost, ctr i'd have to say:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol &raquo;</TD></TR><TR><TD CLASS="quote">I never like to say never, but that is really an NA setup...</TD></TR></TABLE>
Old Jan 27, 2008 | 09:38 PM
Schister66's Avatar
Man U FTW
What's the compression ratio on that setup?? You can boost it, but the static compression ratio is going to dictate how much power you can safely make on a pump-gas grade fuel.
Old Feb 9, 2008 | 01:38 AM
Default Re: (Schister66)
yeah, see ive heard so many yeahs and so many no's im confused i only want to do like 7 lbs of boost but i would really like to try something a little different you no i just figured it would work cuz people boost itr etc all the time. i was planning on getting either the jdm or usdm itr pistons what you guys think
Old Feb 9, 2008 | 02:49 AM
tekturbo's Avatar
If you want to boost with type r pistons go with usdm itrs,but you cant base it all on boost because thats not the factor its all about the tuner and the fuel you are going to run with. To be honest I havent heard of anyone boosting with typers in a lsvtec.
Old Feb 12, 2008 | 11:33 PM
Default Re: (tekturbo)
neither have i but thats why i want to try it.. im using 91 oct. and im going to get it tuned by whitfield racing. if youve heard of that.....but they said they would hook it up im going to use crome so you think it will work
92SikHatchBak
Sep 12, 2009 03:41 PM
umair
Mar 8, 2009 08:26 AM
dc2ls-vtec
Aug 7, 2008 01:06 PM
Satoonxtreme
Mar 9, 2007 04:43 AM
airborne84000
Apr 30, 2003 07:07 AM
