can i boost on this setup??
Old Mar 1, 2009 | 04:52 PM
umair's Avatar
Default can i boost on this setup??
i have gsr block with b16 type r pistons, itr valves omni power retainers. the car is going to have gsr or itr cams. is it safe to boost on this setup??? how much power should it make???
thanks
Old Mar 1, 2009 | 05:23 PM
Ls_dx's Avatar
Default Re: can i boost on this setup??
With tuning, anything is possible.
Old Mar 1, 2009 | 05:43 PM
Milab21's Avatar
also depends on what size turbo you want to run, what are your goals?
Old Mar 2, 2009 | 08:02 AM
b20beast83's Avatar
thats a bit high compression with the type r pistons
Old Mar 2, 2009 | 08:47 AM
umair's Avatar
i want to make around 270-300 to the wheels.
Old Mar 2, 2009 | 11:39 AM
SilverEk3dr's Avatar
I did 100 shot on a setup VERY similar to that. Made 250whp. Didnt have a prob till I ran it lean one night and burned a piston. Other than that it ran awesome.
The opinion has been stated a million times before. With a stock bottom end. U really shouldnt go over bout 300whp. It doenst matter the setup. T1 boosted a 11:1 s2000 and made crazy HP with it. How is that different from your setup?
Old Mar 2, 2009 | 12:17 PM
418whpturboD's Avatar
id do it..
Old Mar 3, 2009 | 04:59 AM
umair's Avatar
ttt
Old Mar 3, 2009 | 06:07 AM
Schister66's Avatar
Man U FTW
With the right fuel, you can boost any compression. You will have to have slightly lower-than-average goals, but it is definitely possible. If you still want around 300whp (usual stock block goal), you may have to run a slightly larger turbo than most people in order to keep the intake temps down, but if you do a little research and find a turbo that will be efficient at your power goals, you shouldn't have any problems building a great setup
Old Mar 3, 2009 | 10:44 AM
fishieman's Avatar
This is bench racing dude.
OP has almost 500 posts. Come on now.
Read the rules..
Old Mar 3, 2009 | 11:23 AM
how is it bench racing??
Old Mar 3, 2009 | 12:26 PM
Schister66's Avatar
Man U FTW
Read the rules..
IDK if it's bench racing, but it is definitely excessive speculation.
Asking if it is safe to boost is legit and asking about a reasonable power goal sounds legit. I could see how you would think it is against the rules, but in the words of good ol' Mills Lane "I'll allow it"
Old Mar 3, 2009 | 06:43 PM
stockb18c's Avatar
this is where e85 loves you...
Old Mar 4, 2009 | 01:15 AM
N I T R O's Avatar
no problem , i was running type r motor on boost 310hp
worked fine
Old Mar 4, 2009 | 11:49 AM
umair's Avatar
i might buy a kit this weekend.
thanks
Old Mar 7, 2009 | 09:00 PM
umair's Avatar
k i got the kit and talked to my tuner and he said i should only get 230-240 WHP.
Old Mar 8, 2009 | 08:18 AM
Milab21's Avatar
what kit did you get?
Old Mar 8, 2009 | 08:26 AM
Schister66's Avatar
Man U FTW
I hope you didnt make a hasty decision and get ripped off on some junk setup. What "kit" did you buy? Also, do you know this tuner is worthwhile??
wist00s2k
Feb 27, 2015 10:44 PM
92SikHatchBak
Sep 12, 2009 03:41 PM
watanabefan
Feb 12, 2008 11:33 PM
Fuzion
Sep 11, 2003 01:49 PM
SpeedMonkeyRacing
Jun 27, 2001 07:22 AM
