Is it safe to run without your timing retard?
Old Jan 6, 2004 | 03:44 PM
btrim23's Avatar
Default Is it safe to run without your timing retard?
yeah, i install everything now. even the check lights won't come on. but don't understand if i can still drive safe and slam the gas? please let me know.
Old Jan 6, 2004 | 08:38 PM
turbosi03's Avatar
Default Re: Is it safe to run without your timing retard? (btrim23)
your not safe until the car is FULLY tuned. it's not worth it man...
Old Jan 6, 2004 | 08:41 PM
highmilehatch's Avatar
Huh? I'm going to assume you just installed a turbo kit with an inline pump and fmu and are wondering what to do about timing. If it were me, and I was running that setup, I would at least dial the distributor back to 14 degrees and run the lowest boost level I could, preferrably 7 psi. Run 93 octane and cold plugs too. I don't see this being a problem.
Old Jan 7, 2004 | 09:22 AM
btrim23's Avatar
Default Re: Is it safe to run without your timing retard? (highmilehatch)
cool....thanks everyone...
WadeH
Jul 25, 2005 11:01 PM
94ta_lt1
Dec 25, 2004 03:45 PM
CRXLST
Oct 27, 2004 09:45 PM
93TurboSi
Aug 26, 2004 12:04 PM
TurboDC4
Feb 7, 2003 02:29 PM
