Turbo a stock B18A1
Old 09-12-2008, 08:54 AM
naler62188's Avatar
Default Turbo a stock B18A1
Ok, so I was thinking about building an LS/VTEC setup to boost later, but then the suggestion came to me to JUST turbo my engine??? IDK alot about running turbos and such but I would like to know what I need to do before I put on a turbo? oh, what kind of numbers can I expect running 12 psi on a stock LS?
Old 09-12-2008, 11:03 AM
thatblkguy's Avatar
https://honda-tech.com/zerothread/1024174
Old 09-13-2008, 11:59 PM
lsvtek's Avatar
Default Re: Turbo a stock B18A1 (naler62188)
here is a thread i HIGHLY recommend you looking at.
https://honda-tech.com/zerothread/1323059
Honestly, I recommend you just boosting the stock ls. I had built my integra's engine for ls-vtec, with the money I spent, it was not worth the 190 whp. If you piece together a kit for your integra, with about 10 psi I heard you can be at 240 whp and more.
Before you boost the car tho, Run a compression test and leakdown test on the engine to make sure the internals are all good. Also how many miles does the engine have?
Old 09-14-2008, 07:45 AM
HiProfile's Avatar
Default Re: Turbo a stock B18A1 (lsvtek)
Spend the money on pistons/rods instead of the vtec head. You can always add it later FAR easier than pistons/rods. NA LS/V will be ~180whp w/o major boltons. Boosted LS/V will limit you to ~250whp due to the thin rods. LS with rods/pistons will get you far past 300whp. In fact, someone had an unknown T3 with his LS and it made 300whp with obvious boost leaks.
NA LS/V if you want to make riceboys wet at the gas station.
Boosted LS if you want to make the audience wet at the drag track.
Old 09-15-2008, 06:40 AM
naler62188's Avatar
My engine has 210,XXX miles on it. I'm looking for another one though. I really want a 92-93 B18A1 that I can rebuild and everything, but the B1s are easier to find. As are the 90-91 A1s. I was planning on doing those tests on my "new" engine when I find one(I haven't really been looking hard though). I was also planning pistons rods valves springs and retainers. Anything else I should get before I go turbo?
Oh yeah and micrpolishing the crank, and after this post as kind of a joke ( https://honda-tech.com/zerothread?id=2386633 ) and twin turbo lol
Old 09-16-2008, 10:44 AM
thatblkguy's Avatar
92-93 B18A1 is the same as the 90-91 one cam has a diff spec thats it and its obd1.
the cam is the only reason it makes 10 more hp. but from looking at the service book it shows the 90-91 making more torque then the 92-93 b18a book the book could be wrong
Old 09-16-2008, 11:03 AM
naler62188's Avatar
Default Re: (thatblkguy)
The 92-93 is obd1 the earlier ones are not. the 90-91 do make like 2 ft lb more torque but I want the B18A1 from a 92 or 93, that's what I have now.
TVietEBoyG
08-14-2007 04:30 AM
Gamefreak0109
21
06-08-2007 02:00 PM
S1NFUL RL1 619
08-24-2006 06:38 AM
WhitEdRift
05-11-2005 09:22 AM
Drag305
11-13-2004 06:57 AM
Quick Reply: Turbo a stock B18A1
